PDA
View Full Version : 2nd Gen Neon
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 [19] 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49
  1. sway bar bracket mounts....
  2. BRAKE indicator light comes on when starting in 1st gear.
  3. Port matching throttle body with intake manifold
  4. A Sad day for me today....
  5. Do you wave at fellow Neon drivers?
  6. A Little Help Please...
  7. need help
  8. san joaquin valley mopar show / cali meet (56k atomic bomb)
  9. What size for pics
  10. Engine taking a long time to turn over + p0440 and p0441
  11. pproblems with brakes
  12. Srtgtr34's Audio & lighting Thread
  13. Need to install power steering pump and Belt
  14. Getting New Tires...Why Not Some Rims?!?
  15. check out my album/looking for power
  16. Help?
  17. 2004 sxt neon
  18. help with exhaust's
  19. needing parts
  20. looking to get best sway bar kit.
  21. Halo fogs
  22. looking for the brightest and best quality H1's
  23. Im back...
  24. need info on gaskets...
  25. Installing An Aftermarket Car Head Unit
  26. hey guys !!!
  27. ebay motor mounts???
  28. Ford coming out with Speed and Stereo Volume Limiter
  29. Fuel Economy The Thread to End all other MPG threads
  30. eyelids
  31. New Headlamps
  32. Research on sound system
  33. N3on
  34. How do you guys measure your MPG?
  35. A night to remember
  36. This just brought a smile to my face
  37. Looking into a 2nd gen neon. help
  38. HELP!!! need new engine
  39. 2000 chevy venture
  40. 03 sx 2.0 starting problem
  41. fuse question
  42. New Cylinder Head Bolts - 2001 Neon ?
  43. 2001 2.0 Neon SOHC timing belt tensioner
  44. Camshaft and cranksaft sensor replacement 2005 neon
  45. TSB Question- PCM Reflash
  46. side skirt
  47. Jegs Master Engine Competion
  48. 00 light conversion to 03?
  49. Rainforest in my 2005 Neon
  50. Free 2004 Repair Manuals
  51. exhaust sound
  52. Neon started skipping very bad!
  53. The Random Noise
  54. Headlights and Tired
  55. Looks like we may be losing another member!
  56. Sentry key problems??? Please help!!
  57. Inner Tie Rods
  58. Any Murdered Neons On Here?
  59. lowered pics
  60. Passenger Window Problem
  61. One Last PhotoShoot Before Winter
  62. Dust Covers for new struts
  63. Winter Projects(2nd Gen Only)
  64. Is this 2 much for Rims?
  65. studdering like crazy
  66. Oil Weight
  67. Ac evaporator removal?????
  68. Bought a Neon with some problems looking for some help!!
  69. Spped sensor in an 05 SXT Automatic
  70. Need Help On Upgrading My Headlights
  71. Gas cap
  72. ? about key fob for 2000 Neon SE
  73. Any one know if a stock srt-4 main
  74. Can't find my 01's problem listed...
  75. Water leaks on an '02
  76. Wtb: 15' tires any size used or new..asap
  77. Performance
  78. What is this on the spark plug tubes?
  79. Where to buy EGR Valve?
  80. Need help..losing ac pressure wtf
  81. SRT-4 engine in my SXT?
  82. 2000 Neon engine question
  83. Carbon Fiber Hood
  84. Motor Mount/Creeking Question
  85. Sunroof Leaking
  86. Drain Oil for Oil Change?
  87. is there any way to...?
  88. Synthetic motor oils
  89. LOOK for this hose!!!!
  90. Need Help w/ sanding
  91. Y'all better vote for me!
  92. These or those.which is better.
  93. highbeams
  94. Gauge pods and gauges????
  95. So what should i do?
  96. Best ECU's??Help
  97. 2.4?
  98. body kit- need an answer fast
  99. Fog light help!!
  100. Wheel help
  101. will these rims fit???
  102. Rex Motor Mounts Inserts
  103. UDP help again!
  104. Car Vibration
  105. Neon rear brakes
  106. Anybody?
  107. Neon sxt vs honda vtex who wins find out
  108. SXT Wheel Hub help
  109. Maybe my MPX Long Tube Stainless Steel Header for sale
  110. ABS Brakes on SXT
  111. few things for sale
  112. 1st gen struts on 2nd gen?
  113. K&N
  114. tried to wet sand...help..lol.
  115. Shop Manual for 2001 Neon ?
  116. 2001 2.0 SOHC vs 1997
  117. Srt4 owners!!
  118. 05 Dodge SXT
  119. anyone who repairs Neons...HELP!!
  120. 2001 Neon Error code: Downstream not matched
  121. Strange noise in the cab....
  122. 2001 Neon with Issues HELP!!!!!!
  123. How much do you drive
  124. TYC brand taillights?
  125. Wow Who knew it would take so long!
  126. Parts from an srt to an sxt
  127. '03 Dodge Neon Cutting OUt
  128. codes???
  129. the neon is back, for real...lol
  130. Chrysler neon.....
  131. suggestions new bumper
  132. List of what I have done this month
  133. 02 Neon Gauge Cluster Swap
  134. what do i do to lower my car
  135. Ebay radiators
  136. what type of engine do i have
  137. Tranny question
  138. Engine Noise
  139. brakes
  140. gauges
  141. jobless
  142. srtd bumper and hood
  143. Hey New to this Dodge forum. Need some help.
  144. Headers for my neon help please
  145. help
  146. Trans ?
  147. Those of you wanting to turbo your 2.0 SOHC READ THIS
  148. the neon is back!!! well atleast my neon is...
  149. Neon Header Question....Input needed!!!!
  150. how to install a anmeter???
  151. Have a problem, need an answer. :P
  152. Purge Kit?????
  153. wtf ar wont re past 5317 rpms
  154. Damn This sucks.
  155. I'm adding fog lites (on a non fog bumper)
  156. I hate theives
  157. ACCIDENT - Help
  158. I need help to fix my 2001 neon door lock (manual)
  159. Car vibration, wtf??
  160. Issues finding parts and need help
  161. 420a
  162. Spark plug wire problem
  163. 04 neon mechanics book?
  164. UDP question
  165. 2001 neon, outside door lock not opening by the key
  166. My goodbye story
  167. new exaust
  168. transmission parts... for built tranny..
  169. 2002 Neon Engine/EGR Valve
  170. Front Wheel Hub Bearings
  171. Trolley/Floor Front Jacking Point?
  172. any1 seen this?
  173. I Want To Form A Car Club
  174. anyone know what this is
  175. Installing New Antenna
  176. can you say rip offs???
  177. bye-bye neon--sort of
  178. powder coated valve cover? $ ?
  179. is it REALLY worth it???
  180. Well it's official guys
  181. 1st gen TB bolts up to 2nd gen??
  182. cavy update
  183. a few questions
  184. Post a pic of you and your car
  185. Transmission Question
  186. headgasket
  187. R/C cars. You got any?
  188. DF Video!
  189. Coolant Flush Help
  190. Good Deal on lowering springs?
  191. Best/easiest swaps???
  192. transmisson
  193. For all you 3-speed auto people there is a solution
  194. Problems
  195. extra keys and oil question
  196. buying a srt4 hood
  197. Had a baby!
  198. ODB Cable??
  199. installing xm, ???
  200. CEL Code P0340
  201. catalytic converter ques.
  202. Put my gallery up...
  203. Evap Control?
  204. taking a long shot here
  205. 2000 dodge neon Question?
  206. oil opinions
  207. College
  208. Diagnosing A Sticky Brake Caliper?
  209. What my lip kit would look like....
  210. 2002 Neon "error" message
  211. 02 wont start - dunno about 2nd gens.
  212. Im Looking For Good/Best Spark Plug Wires
  213. The sound's of Beauty...
  214. Identifying the correct fuse
  215. A/C opinions needed please
  216. Where did my Project Thread go????
  217. would yo trust JB weld?
  218. 2001 Neon replacement Stock Pistons. Where to buy?
  219. painting advice
  220. my clutch crapped out :(
  221. Totally made up my mind on what front bumper i want...
  222. I need help with a code.
  223. awd conversion
  224. No A/C...2001 Neon R/T
  225. audio system
  226. It Growled At People
  227. Seat Covers
  228. What plugs are you runnin in ur 2nd gen Neon??
  229. Where is output shaft speed sensor located
  230. Wiper Fluid Won't Come Out
  231. Need OEM 15x6 10 spoke alloy wheel ASAP
  232. pmc switch
  233. Got smoked by a stock cavy...
  234. Will these rims fit my car....
  235. Exhaust Question
  236. New leak, wtf?
  237. My Exhaust Video....
  238. so... for my birthday....i wanttttt
  239. i have a serious problem
  240. i have a serious problem
  241. Faded bumpers
  242. Coolant/Temperature problems in my neon. Need Help!!
  243. The 2nd gen neon social group.
  244. '03 timing belt?
  245. intake manifold leak
  246. engine code p0480 cooling fan circuit malfunction....FIX
  247. bloody light
  248. troubleshooting clockspring
  249. Fuel gauge reading backward
  250. crane 10 or crane 12
