- 2.0 turbo ??
- Where can i get this?
- plans
- Who has done the srt4 swap
- hey 04RTNeon
- 17" rims?
- bad oil leak info please
- Porting Intake Manifold?? 60mm TB bogging car...
- What mods to do?
- Service Manual?
- ALL DODGE NEON BULB SIZES!!
- Wheel Spacers
- srt- 4 turbo
- Transmission Problems?
- Where can I get an SRT-4 stock body kit?
- Sunroof Install
- help making tuff decision
- VSS & Tach wire colors @ PCM
- car stereo + speakers
- FS: Wrecked Neon
- Few things F/S!
- New r/t bumper and custom fitted vibrant dual done!
- Looking for exhaust and CAI
- Whats the best cam for turbo setup
- My dodge neon se
- Got a few problems with the ol' neon.
- Bored...pic of my neon
- Tokico Struts
- stiff brake pedal???
- Exhaust heads up
- Check engine light
- got the intake on...looks and sounds great
- Plate bulb
- wat ur opinion on dis
- MOVED: a bad miss under throttle
- Yet another rim thread
- Sparkplug Well Problem?
- Hahn Turbo system Help!!!
- lower control arm help to get bolt out
- 2002 neon trans problem, help?
- MOVED: Replacing EGR VAlve
- spark plugs
- srt4 throttle body
- exhaust sounds
- intake manifold anyone?
- horsepower
- high flow catalytic convertor
- srt-4 anybody?
- Dodge Neon ACR SRT-4 Racing Buckets f/s
- Finally Done with the front end
- UPDATED: NEW PIC TO KICK BAK & LAUGH LOUD!!!
- Resonator
- New Project Thoughts...What do you think?
- has anyone tried this?
- drivers side lock malfunction
- Hood
- turbo pic
- being dumb
- Crane Cam Wires
- 2000 Neon fuse panel translation?
- Tires
- HELP ME OUT PLZ!!!!coil over front lowering prob.
- erosion
- My 4th one...
- car resets
- manual to keyless entry?
- Quick question- headlights
- 05 SXT Throttle
- R. Lip
- Removing the cat??
- Got Quite a few questions
- Lowering Springs FOR SALE
- Magnum HO 2.0 Motor vs Regular Identification
- Trans Torque Limit
- 02 sohc
- Car at the paint shop for new bumper and exhaust!
- Gas Guage not accurate
- Grease/Lube Points
- Help trans cooler install
- GOT THE K&N FIPK GEN 2 INTAKE
- Adding a new Key!
- Bottom End Rebuild Difficulty
- tire question...
- fuel pump ?....
- help with neon
- srt4 TIRES question...
- Lowering and rims
- Goodyear Eagle #1's
- cold air intake
- power steering problems
- Auto Downshift
- best place to get SXT/ RT style spoiler
- 2003 Dodge Neon Se Ignition wire...
- Got the pics. let me know what you think.
- Cleaned My Car, and Finnally Got Some Pics!Warning Pic Heavy!
- Driving hard good?
- potential mopar kit for sell...maybe
- key in ignition chime?
- 2.0L Motor
- bumper
- LED Tail lights?
- headlights repair kit?
- any neon owners wit fog Lights?
- Brake lights/ Turn signal problem
- Mounts
- So...
- Fog Lights Not Working
- MISFIRE? BAD FUEL? WATER IN THE INTAKE?
- Need a conensus, srt-4 exhaust fitting r/t cut outs??
- check engine light
- Another Engine Swap Thread...
- struts and stuff
- ATTENTION: Potential SRT-4 Swaps
- Your Opinions
- I Want To Say (255 limit)
- UDP
- anything illegal about this tail-light mod?
- drum brake... is it screwed?
- Unlock All Doors with One Key-Fob Click
- Kansas City/Lawrence area painter?
- quick question
- Fav Mod
- Prothane Kit number just in case....
- R/T bumper
- "Rolling" an r/t bumper
- msd plug wires!
- Another Video of my Neon doing a flyby.
- Video of my 2000 Dodge Neon doing a flyby!
- '01 Neon fuse panel diagram?
- My day
- touchup paint
- R/T Manifold/Brakes question
- MOVED: racing
- Gauges
- M/T won't go into reverse
- sunroof will not open
- Engine code link ERRORS
- Electrical problem
- Hedman Headers?
- anyone looking for a chrome rim?
- SRT-4 Exhaust with 4" tips fit in R/T Exhaust slots?
- my seatbelt is stuck..
- srt4 style exhaust for sale
- help!!!
- Airwolfs flip flop trunk!
- this should fit right.
- So, there's these lowering springs...
- Override switch for the fuel pump...
- 2003 Dodge Neon SXT color codes?
- Some other pics of the header and 3" downpipe and 3" cat..
- Pictures of the Neon just detailed and pics of the new rims in the box!
- Button On the OBD-II Panel
- CD Player Won't Eject...
- Mopar Super Center - Is it Trustworthy???
- Broken rear wheel stud - HELP
- Trunk rattles
- engine block?
- srt-4 wing need quick help
- 02 auto steering problems
- 2003 Dodge Neon - How to get to your tachometer/speedometer
- eyelids
- where can i get a clutch for my 04 sxt?
- Radiator
- wut should b nextupgrades
- Noise from Rear Driver side wheel
- Water LEaking In Trunk!! HELP ASAP!!!!
- Booger Bushings
- no power
- Neon Carpet?
- Getting an r/t bumper, whats a nice loud exhaust for the R/T setup??
- smelly a/c
- Project Begins
- Koyo Aluminum radiator
- What to buy?? need a lil help
- What you think the best cam is?
- Good Transmission for tuned neon?
- 2003 neon sxt - Interior Mods?
- MOVED: 1997 NEON PROBLEM
- Wiring Schematic for Ignition System
- sticky suggestion 03rt
- NEON RIMS.....
- little help?
- Engine codes
- Fog Lights on 2005 sx2.0
- washed my car
- My Neon Pictures!! Check it out for a second!
- will these rims fit?
- popping noise...please help
- coilovers for sale
- Anyone have pics of a dual BORLA on neon???
- does anyone have a wideband?
- stalls at the same place and manual ?
- Borla Catback Dual Exhaust
- 3 speed to 4 speed automatic?
- Front Brakes for 2001 Neon
- srt swap
- governor
- Water everywhere
- Remote start system for 05 SXT?
- 1st buy
- Raced a Mini Cooper S
- ebay chip?
- underdrive pully
- Lowering springs
- Exhaust Cut-Out Issue?
- Just Bought 00 Neon for 50 BUCKS! Have some probs tho
- 02 neon engine problems
- Have a white Neon with window tint?
- What Springs for a '05 Neon? Want a 2"+ Drop
- Need Help
- Items I need pt2
- All cleaned up for summer
- Power rear windows Kit
- sway bars on an rt
- summer plans (Pic heavy)
- another fuel pump ?
- fuel pump question
- 2000 2.0l 16v work with 2004 SX2.0?
- I'm looking for a dual exhaust for an 05 SXT. Recomendations?
- I can't believe I did that...
- Dreaded Trouble Code P0601
- ey ssisrt-4 wing
- Selling the neon r/t
- Turbo question.
- Introduction + What do you think of these rims? and my fix up ideas?
- Custom Exhaust cut outs?
- p0508
- *REALISTIC* Dream Cars
- Z3 fenders for sale
- Srt-4 Rear Bumper on 00 Neon
- FS-12in Kicker Comp in Ported Box
- ebay body kit?
- performance chips
- P0171
- flexpipe questions...
- Anyone running 215/45/17's on the Neons/
- suggestions on midpipe with cat
- Want to hear a sob story?
- Almost how my car should have come....
- RIMS ARE IN!
- Little help guys
- poping noise in steering
- Will a SRT4 rear strut bar work on a SXT?
- need your opinoin on side skirts
- bypass MAP sensor?
- Items I need
- Those of you that did SRT-4 engine swaps...
- Harmonic Dampner - Reinstall Problem
- what u think of flowmaster 60series muffler for my neon
- Modern Performance . com
