- Having problems with my neon
- 2.4L SRT4 Engine in a RWD CaR
- nice ref. pics if doing some major eng mods, like underdive pulley or internals
- govener
- Automatic Tranny for Manual
- I need help!
- Very important question plz help
- Where is the Oil Pan?
- Starter Install
- insatlling a starter on a 98 Neon SOHC
- I wanna paint my interior
- accerleration and uphill questions????
- Could it be?
- Compression Ratio
- Questions
- Flash ECU/PCM and Tune..
- Just a thought
- Has anyone had problems with the TPS sensor??? P0123
- Nice Rims
- wiring lights
- Cleaning Engine tips
- that sux
- solid motor mounts
- DO 2Gen Autos have a tranni comp or just a PCM??
- cold air intake & exhaust
- SRT-4 Seats
- hellp
- question
- selling
- Fuel Filter
- Out of Car Fuel Injector Flush?
- aux line in ?
- engine code????????????????????????????/
- Speaker sizes
- fiberglass hood
- 2001 Neon wheel size
- Loss of power and gas mileage! Help!
- CAN Automatic 2GEN neons shift on 1????
- Fuel injector cover bolts parts numbers???
- SOMETHING GOOD ON EBAY!!!! IM NOT KIDDING!!! L@@k!!
- Tach hook up...
- mufflers
- Engine Code P0340 & P0344 Please Help
- Platinum Plugs BS?!?!
- Best plugs for my neon
- Transmission Flush Question
- Help Rebuilding an Engine!!!!!
- 2002 dodge neon transmission fluid leak
- Water Intrusion
- Misfire Troubles
- check this out
- Why does my car tremble?
- help with cia
- shaved doors
- dumb stereo question
- Its official
- NO MORE THIRD BRAKE LIGHT!!!
- A few body ?'s......
- Power Door & Window Kit...?
- keyless entry replacement. help please.
- Off set?
- Hood?
- MY CAR SAID DONE... I SAID... WHAT DO YOU MEAN DONE... it didn't answer me maybe you can...HELP!!!!!
- Question about rewiring power outlet.
- side marker lenses
- 04 Neon with Power Steering problems when its COLD out side ONLY
- Carbon fiber hood Question.
- Trunk Neon
- NEWBY wants to do some upgrades- Need suggestions!
- chips
- From normal auto to R/T auto???
- coil pack question
- Neon dies when lights turned on
- MOVED: Any FLORIDA neons, post here!!
- ? on aftermarket taillights
- 00 Neon heater/very little heat output
- no codes
- 2000 Neon buying advice
- P0340 (M) No Cam Signal At PCM No fuel sync
- Power Steering
- CEL Code P0441?
- so i may have totally messed up my neon.help!
- Are you kidding me no Philly neons in this place.
- mounts
- finally bought a neon
- Stereo quick question
- P0622 code
- Check engine Light
- exciting isnt it
- Getting Pulled over.....
- Front Bumper Cover
- New Pics!!
- Cd changer
- delete
- freshwater flood 2" on floor..do i buy?
- quick ? about a hood
- Tachometer Clusters
- need someone with a 2003+ neon
- Oil Cap??
- rims?
- check out da new pics
- quick help please
- How much hp will it ad?
- my 200 dollar neon
- Aluminum Valve Cover...
- SRT vs SE Body wise
- SRT-4 cosmetic parts
- What size Socket do i need?
- Removing Stock Head unit
- just have a question
- Snow tire question
- How many passengers have you ever had inside your car at once?
- Welp... i finally bought some audio equipment...
- What are my options? 01 neon es Rear bumper
- 2005 neon quarter panel
- UDP ?
- Coilovers
- computer code+Tranny+dimming lights= BIG QUESTION
- Tail Lights
- from 2.0 to 2.4
- SXT Front Bumper
- VVT Heads
- Direct Fit Seat Covers On EBay
- What is with the brakes/rotors on these cars!?!?!?
- Side moldings Removed!
- A/C bogs car down at a stop. Any suggestions on wat it might be?
- is it worth it?
- good first mods?
- Intake manifold
- head port and polish or swap?/ timeing concerns
- 'nuther side mirrors question, replace?
- i think i solved my starting problem but i'm confused why
- Hissing from engine at certain RPM? help!
- has tthis happened to anyone? Please help!
- Poly mount inserts motor and tranny the same!?!
- MOVED: To funny not to post this (vid)
- UDP + subwoofers?
- where do i get eyelids
- turbos
- headlights
- how much can the block take
- 01 fitment
- maybe a silly question, but, what model do I have? ES? SE?
- North Jersey Neons!
- Turbo Manifold Question
- new CIA
- 2003 Neon SE
- price for fixing tire rods
- black to silver neon fenders?
- 2005 Neon 2.0 M/T AEM Intake System
- P1648 Trouble Code
- Do I need to buy a Camber Correction Kit?
- MOVED: Turbo idea for my 5.2
- short shifter
- Harness
- SRT-4 Conversion
- Where is the IAT Sensor?
- Websites for aftermarket products
- 2.0 MAGNUM TURBO MANIFOLD
- Neon rt bumper on an es?? will it work?
- Exhauste any suggestions
- Any tips on getting it faster
- a new seats question
- Finally Dropped the R/T!!!
- install of cam
- Shocks & Exhaust
- Dyno run
- need help 02 neon r/t control arm bushings
- suspension question
- upgrades
- Header installation
- chips
- new 00-02 Projector headlights
- Noob...Rear seat interchangeability and warped Rotors
- Help with odb p0703
- Motor Mounts Are Broken
- MOVED: SRT-4 Question
- place to buy turbo manifold?
- need help fast please
- Spoiler Added.
- noise from engine
- ecu
- just ordered
- STS installation
- Oil in spark plug hole
- 2005 Dodge Neon Cargo Net
- manifold Q.
- Starting issues
- New Exhaust
- new engine
- SRT-4 seats
- Neon Owners in Maryland???
- interesting day
- please read
- 2.0 sxt want to swap for an srt motor
- Right hand side driving?????
- grounding kits
- Most Popular CAI???
- swap single cam for dual cam
- HELLLPPPP!!!!
- neon undercarraige
- 2002 Neon ES Gages going crazy when car turned on
- Car slides, when I hit a bump.
- loose belt's on underdrive pulley
- Change my neon
- NEED HELP!!! 2001 Neon Stalls & Jerks when I press on gas
- Good Dent Remover?
- Problem... Help...!
- Spoiler question!! (and air filter question)
- SRT4 tb
- 2000 neon won't start
- HRC Turbo for sale on ebay!
- A little LED work...whaddya think?
- push button
- multifunction switch??
- srt manifold
- lookin to buy a neon-- bought one!
- Widebody?
- Intake
- WTB purge kit and bottle
- Need new seats for my 95 neon (2003+?)
- Question about CD changer(I feel like an idiot.)
- Pics of my bagged neon
- srt-4 exhaust
- Question????
- NEED YOUR HELP
- exhaust
- sx rt wheels, will they fit?
- Where did it go???
- Black Headlight mod
- superchargers
- What do u think of windshield spoiler?
- EBAY CAI need help ASAP After install
- Bolt On's....
- WHY the MPG so LOW!!! ONLY 21mpg!
- Dirty 2nd Gen Thread
- wanted turbo manifold
- Q about short shifters and lowering springs
- check this out
- springs
- 02 dodge neon intake manifold / seats
- Why Swap?!
- 2 questions
- single wiper?
- eBay racing seats
- HRC stage 2 turbo kit for sale
- STS ?
- 2 questions about headlights
