View Full Version : 2nd Gen Neon
- engine sawp
- Specific Mod ?'s Need Help!!!!
- looking for LSD
- new
- Reconfig
- exhaust manifold...are they the same
- 15 x 6 Wheels
- will 1st gen wheels fit a 2nd gen neon?
- Russell PRE-ASSEMBLED, DIRECT BOLT-ON BRAKE LINE KITS
- Paintin side mirrors
- fog lights?
- How much?
- question
- rear brake conversion
- problems with an Amp..
- LED lighting
- map sensor clamp
- LCD screen
- Has Anyone put these Headlights On?
- question?
- '03 Neon SXT sputtering/losing power under load -- What's wrong?!?
- HELP!! Shopping list for motor rebuild and turbo
- Shifter play
- Help me please!!!!!!!!!!
- How to fix P1490 (M) ?
- 2000 to 2002 se
- Exhaust Question
- radar hardwire Q's
- Removing 2000 Neon driver's side door panel
- eyebrows?
- Engine overheating
- Q about spark plug, rim, engine, and fan
- apexi safc2 wiring diagrams
- How many miles do you have on your neon?
- In-dash speakers
- valve cover
- MOVED: Sound Systems
- what do you think *PICS*
- hesitation
- '04 VSS (Vehicle Speed Sensor) Signal
- new turbo/exhaust
- How much is my car worth??????? PLEASE HELP
- Weird noise coming from the hood?
- Smelly A/C on 2nd Gen Neons
- Where to get steel wheels?
- How Much Oil?
- help turbocharging an 04 SXT
- Instrument cluster with tach
- swap help
- New Sound System Suggestions
- need information about fuel injectors on 05sxt
- resetting PCM question
- Minimum rotor specs?
- Manual Transmission noise
- lean and rich
- Motor Mounts
- Automatic Transaxile band adjustments
- Alternate Ignition Coils
- New CAI
- Engine shakes, steering shakes, car shakes...WHY?!
- How much would my car be worth???
- Black Smoke Coming Out back
- help
- Where do Neons go to die?? (and who has all those BoW Int Clusters?)
- CAI.. a thought....
- Shaking Steering Wheel
- Weird tail light problem
- CAmshaft
- Problem with my inmobilizer! HELPP!
- Turn on lead wire
- location of seat belt chime
- help!!!! oil ON spark plug and oil light
- Gas mileage update, what are you getting?
- 2000 Neon Lx Idle Problem
- have a question
- 2000 Neon, front wheel bearing replacement?
- updated pics
- Check it out
- Help With Engine Upgrades
- larger size rim/tire = better handling?
- 2002+ 2.0L SOHC Engine
- SE exhaust?
- INTERIOR!!!!!!! HELP
- In dash 6-cd changer
- Sub/Sound System Question... Need Answer..
- My new toy...
- Brake problem???
- New NEON & ?
- weird sound....
- silver SRT-4 spoiler
- Springs anyone?
- turbo
- tranny swap Q...
- disc brake system (R/T vs. SRT-4)
- dumb question bout taillights
- Interchangeable?
- neon to srt
- Beep
- shifter knob?
- 04 Grill question
- HELP ME!! w/ exhaust
- 2000 Neon Oil Pressure Sensor
- Gauges
- antenna
- Just Curious (chrysler neon)
- CarDomain Listing, Add yourself....
- R/T logo floor matts anywhere?
- 2000-2003 Neon 2.0L M/T w/o ABS AEM Intake System
- timing belt tensioner
- Front lip
- OEM AC 2003 Dodge Neon SE
- 5 Different Error codes all at once, 2001 neon HELP! I think there connected!
- Condensation on Headlights...
- fuel gauge
- question on dash gauges...
- Exhaust question
- Mileage Change Problems
- PT Cruiser 2.4L into a Neon?
- Subwoofers and amps what do you all have in your neons?
- turbo manifold for 2.0
- Info on CUSTOM interior
- front driver and passenger side noise.
- Custom subwoofer box
- if i was to have this installed...
- Shorty antenna
- Want to build a Neon race car. PLEASE HELP!
- ebay CAI question
- I am new
- help /w my engine codes plz
- motegi wheels
- SRT4 Combo turbo for sale
- selling obx race header & downpipe and r/t style muffler
- RIM Web sites
- RIM Web sites
- VOLTANT
- engine shaking
- Cam?
- totaled
- Rims questions???
- wat will a neon beat
- guess wat
- 3spd auto transmission limits...
- my car :)
- difference between the cold air intakes
- good site for cold air intake
- good site for headlights & taillights
- What do you think?
- Strange problem, Help please!!
- Zenn Springs
- Loose E-brake cable?
- wat do u think of this of ebay
- Parts for an SRT 4 TURBO
- Stainless brake lines
- Tried to break in AGAIN!!!!!!!
- QUESTIONS!!!!!!!
- Camber Kit, hard 2 Install???
- Why are all rear windows manual?
- i was can a srt-4 intake fit on a sxt
- Hello
- str4 spoiler
- gas light?
- exhaust suggestions
- part name? connects hose to air intake/filter
- Code P0841 with P0700...PCM problem?
- Adding an amp and subs
- Car Bogging down in 1-25 MPH range
- Engine noise + water leak
- AfterMarket Antenna
- OEM?
- Sponsorship Question
- question
- Radio
- What ya think?
- FS: 2nd GEN ACR stock Foglamps
- someone help me please
- EBay Wheels
- 60mm MPX throttle body
- DOWNLOADABLE WIRING SCHEMATICS
- Hesitation problem ... solved
- electric supercharger?
- clutch and flywheel
- How hard is xchangin MotorMounts
- need advice on 05 sxt neon
- check engine light came on
- Dash/interior lights flicker and gauges jump
- suggestions? help
- MSD POWER COIL TO TACH ADAPTER?
- Mileage
- +2 Bosch Plats.
- Whoohoo! ridin' with an SS
- torque steer?
- where can i find these?????
- I'm new!...pics of me beast...
- Clarity
- got my turbo finaly!!!!
- Sleeper
- Help car wont start.
- Building Up a 2001 Neon 2.0L SOHC
- Upper Control Arm Bushings...
- cigarette lighter won't work (checked fuses)
- thinkin about something
- hood question
- 2000 Neon Temperature Sensor plug
- Radio
- 2001 Neon Idle Problems...
- Noise on Start up
- Engine stalls after start up
- 1st and 2nd Gen neon, hood latch??
- New Suspension help
- Reverting to Stock Exhaust
- FUel filter 2001 is it the screen..
- taking off an antenna
- will srt4 stock rims fit on my 92 dodge stealth
- weird situation
- Rear strut
- so madddd
- controling a turbo
- not starting right
- Speedometer changes
- Projector headlights?
- hood scoop, faster accel.
- My car got broken into!!!
- Valve Cover Question
- ebay coilover springs?
- Exhaust 2004 sxt with sway bar
- fuel filter?
- 55mm or 60mm TB?????
- Loosing Back Pressure???
- Best Performace Spark Plugs?
- installing an SXT cluster on my 02 ?? (feasible?)
- Just hit 40k, What Should I DO?
- P 0551 (M) Error Code
- where can i find a turbo?
- Difference between the 2002 2.0L and the High Output 2.0L?
- Lambo Conversion Help Please
- motormount inserts
- Installing a UDP....
- Reset the ECU?
- Help Removing drives axel
- 2003 Neon Body Kits
- AEM CAI
- won't start
- Door Ajar Sensor?
- wiring questons
- JUST GOT MY UNDERDRIVE PULLEY...
- Your thoughts
- strut bar
- CAI and the O2 sencor?
- srt exhaust on sxt
- just a question...
