View Full Version : 2nd Gen Neon
- 2004 Dodge Neon Dash Light Question
- Speakers
- Strut bar
- rear window replacement
- Bad gas mileage, help!
- Weird Shifting issue
- messy interior!
- I've benn hearing of an idle adjustment screw?..
- 2005 neon starter issue, no crank
- 2001 dodge neon
- rough idle, hesitation, lame acceleration, sad driver
- APPS? What it is?
- Tranny, Torque Conv, who knows..??
- OEM or aftermarket engine/tranny mounts?
- Changed shift cable. Still problem. Please HELP!!
- New Tires "fixed" my speedo!!
- oil in PCV valve...
- misfire issue
- Changed oil..better sounding engine
- 2003 SXT hard shift
- RF inner tire wear
- Just changed tie-rod end
- Have to crank twice
- P 0420
- GAS MILAGE--->What have u benn getting?
- Ladies and gentlemen, I have a new car.
- 2000 Dodge Neon with PROBLEMS
- Connecting rod bearings
- Engine noise.. Here's my POS -->
- I need help finding a website to order parts from.
- What's NEON stand for...
- 2001 neon timing belt slipping off cam please help!
- Seafoam!!
- 2001 Intrepid rims on an 02 neon.
- Odd heat problem
- FlowMaster 60 Series Delta Flow on 2004 SE
- 2000 Neon Injectors
- lost keys
- Tranny fluid level
- 2003 Neon - Repairing damage from attempted theft
- FUSE NO BUS on my 2000 Dodge Neon
- P 0513 and P 0340
- 2003 Neon Won't Start-Anti Theft?
- 2005 Neon Se...Broken Timing belt, bent valves?
- Front end "hop"
- Anybody need parts?
- 2001 neon tranny
- 2005 sxt cranking trouble, im stuck!
- Quick help identifying belt
- rear brakes locked up!?!?!?!
- won't go into reverse
- 1999 transmission on a 2002 Neon
- 01 neon 2.0LE engine swap for a 2.0LX 01 engine won't start Help
- magnaflow or flowmaster?
- what kind of after market muffler is good?
- Need help with outer window weather stripping
- Vibration problem
- engine swap
- 2001 Heating Problems
- 00 neon coolant leak at idle once warmed up
- turns over doesn't start.
- Shifter Spring
- rubbing noise when i accelerate
- previous owners wiring mess, need advice
- 2000 neon es exhaust question
- Car stereo stopped working after I took out the carpet
- 2004 Dodge Neon making grinding/rubbing noise!!!!!!!
- Tiny vacuum hose...
- Vibration, EVAP, RPM Drop
- Zero fuel pressure
- Lowering Springs
- Engine Mount Replacemet
- need help
- 2001 Dodge Neon transmission noise
- Headlight bulbs
- Burning Oil
- check engine light blinks 10times
- outside noise coming through my speakers
- vibration while accelerating from 1k to 2500 rpm
- Automatic transmission problem
- oil pressure light
- 05 Dodge Neon Temp Needle Bouncing
- Plethora of Problems
- 2003 neon se isnt firing
- what do these codes mean?
- How To Tell If It's Lifter Noise or Piston Slap??
- starts up and reverses
- oil change help 04 sxt
- srt and r/t onto se part swap
- Total trans fluid capacity '03 Neon SXT?
- Wont run after jumped
- Speakers crackling...
- 2000 neon bogging down / power loss
- Computer Question
- 2000 Dodge Neon Unknown Vacuum Port
- Radiator Fan runs all the time
- 2003 Neon Ignition Issue
- I need Some Engine toque specs please !
- what causes P1193 Inlet Air Temp Sensor Voltage High??
- Block Heater - 2000
- battery light
- 2001 Plymouth Neon
- Can't make heads or tails of the AC/Heating wiring diagrams
- 01 Neon stalling same place every day
- 03 Neon Won't Start
- torqe strut
- 2005 SXT Muffler
- 2004 SXT Overheating
- 03 dodge neon air baffle: how to install
- 00' to 05' Interchange
- 2005 SXT won't start
- Timing issues
- neon starts at 5,000rpms help?
- R & R Back glass
- Clicking sound while rolling
- HIDs
- This girl needs some advice on front end repair 2004 Neon Sxt
- 2001 neon trans/transax
- lowering my 2004
- 2005 Neon SXT Exhaust
- engine replacement pointers
- turbo for the 2.0?
- barometric pressure?
- Firing on two cylinders
- Error Code P0340
- Engine Runs rough, out of ideas!
- Gas pedal sticking? Please help. Urgent!
- Bent valves
- Carpet Removal
- Any Suggestions?.....
- OBD Plug Dripping oil
- Oil Drain Bolt
- Newb needs Help
- Coolant Reservoir Melting??
- Popping When Turning
- 2005 SXT issues
- Weird Rattling Noise from the air vents?
- 2000 neon no-start
- 05 stx Issues..
- Headlamps/Highbeams not working! Im going crazy
- timing belt help
- 2003 Headlights
- headlights dont work help?
- a/c helpp meeee weird
- Weird Issue
- Alignment problem, something bent.
- Radiator?
- broken timing belt
- Creek noise when i push in clutch
- A/C problem, very strange
- (Almost) Dead Passenger Lower Motor Mount thing
- splash guard for passenger/drive assembly??
- 2001 Neon Over Heating
- Front end noise on my 03 SXT
- 2003 Dodge Neon R/T
- Looking for a Door latch assembly
- Replacing my timing belt, Belt walking off pulley
- Glasspack
- Spark Plug Thread Sleeve?
- Leak under RHS front wheel
- 05 sxt won't rev past 3500 RPM
- 05 to an 02 Engine/Tranny Swap
- 02 neon trans compatibility
- 2000 Dodge Neon Won't Start
- help fast Throttle body line dont know ?
- Transmission Pan Compatibility HELP
- New to Neon world, Car Bogging, Threw parts at it, still no go! HELP Please!
- My car is pulling to the right.
- Shifter Knob Question
- HO alternator and PCM question
- 2001 Dodge Neon ... Problems
- Engine code issues
- 2005 SXT valve/head question
- 2002 Service Manual
- performance chip for 03 dodge neon r/t
- 01 SE tire/ rim suggestions
- fuse?
- Oil light came on then car stalled
- 2001 Neon Overheating - Details & Video
- What part doi need
- Shift Boot
- 03 SE quit driving
- Oil in spark plug tube
- Power Loss Issues. Last hope before the junk yard.l
- My Neon Suddenly Quit Running! Help!!
- New PCM/ECU?
- 05 Neon won't start
- Upper Motor Mount issue (with pics). "How screwed am I?"
- Engine starting sputtering, now my AC isnt working
- 2002 Dodge Neon Grills
- One wheel is not turning left/right
- 2004 , dodge neon p0016,p0344,p0339 codes
- car ticking...
- Rough all over...
- Possible Oil Pressure Problem
- Rebuilt 2001 Engine, No start. Is it SKIM?
- 2002 antenna
- Fuse #21 blowing
- Aftermarket head unit install?
- Filter question
- O2 sensor--ULEV, LEV????
- 2005 Dodge Neon - had a dealer service warranty - questions about maintanence.
- gas pedal LMAO
- p1390 once warm
- A/C problem
- 2004 Dodge Neon Head
- 04 SE, after changing Camshaft Position Sensor, high rev in P and N
- Help ASAP Engine no Start
- SRT 4 swap or Crate Motor
- Broken timing belt, p0339 code 2004 neon
- Is this the part?
- 2002 neon transmission issues
- 01 neon drives rough
- 2000 Neon not starting, spark plug has oil on it
- are my struts bad? people tell me they are but i have my doubts
- Does size of emblem matter?
- ATX to MTX
- 2000 Won't crank, start, or run!!
- Ground control coilovers
- Car is unlocking itself! Please help!!
- Neon unlocking itself
- Door Ajar Warning
- Iceman CAI?
- Battery Problem, Please Help!!
- 02 sxt humming noise, pitch changes as speed increases/decreases
- Instrument cluster, again
- Dual Fans
- 2005 SXT not starting.
- no speedometer, high revving, etc.
- Exhaust Upgrade Options
- Intake Manifold
- Oil catch can?
- 2003 Dodge Neon Automatic to Manual Transmission Swap
- cold air intake question?
- 05 a/c ?
- my Neon stalled with P0352 code
- Take sway bar off and drive?
- 2000 neon wont start
- loose throttle cable
- New Dodge Neon Owner, need help!
- Does anybody have any Plymouth/Dodge Neon parts?
- How would springs and stock struts mix?
- 2003 dodge neon parts for sale
- Can someone please help me-spark plug tube seal
- odd noise(throttle related)
- engine problems
- 2000 dodge whines and idle horrible
- Cant figure out whats going on
- ATX oil pump removal trick
