PDA
View Full Version : 2nd Gen Neon
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49
  1. Need help with suspension 02 neon
  2. 05 SXT radio questions
  3. Aftermarket Tachometer
  4. 2005 SXT interior lights LED & center dash
  5. turbo oil feed line help!
  6. 03 SE Struggling At Stops, Broke Down Today & Restarted 20mins Later
  7. Dreaded P0700 and P0888 Codes came up after grounding
  8. Head and Head work
  9. Hi I'm new an my neon doesn't run!
  10. I need help with my neon's EVAP system
  11. Code 21 and Code 22 Help...
  12. 02 tranny
  13. Can't find the ignition wire for my remote start
  14. 2001 radiator fan not working
  15. No problems with car, But!
  16. turbo 2005 neon?
  17. Why do I keep getting error codes?
  18. Neon motor problems
  19. Srt4 bucket seats and srt4 cluster for sale
  20. Motor Mount Bolt
  21. 05 neon wont start
  22. New member with some questions! 2003 SXT
  23. Clunk when turning
  24. horn doesnt work
  25. 2000 neon tranmission ???
  26. PCV Valve won't stay in
  27. Aftermarket HID High Beams?
  28. So what is this special tool L-4553
  29. oil pressure gauge
  30. 01 Neon problems help asap
  31. So long
  32. Starter engages and starts, then won't...
  33. New Guy
  34. Oil pan?
  35. Popping noise
  36. 03 SE Oil light and other issues
  37. 05 neon dead in the water
  38. lower my neon ?
  39. 2003 Neon SXT loss of accessories.
  40. Help w/ '03 Neon: smoke from vents, transmission slipping
  41. seized trunk lock
  42. ovrrheated.....again
  43. head milled
  44. 03 Neon Trouble!!!
  45. New brakes
  46. r. front spindle
  47. 2003 Neon - Vibration and Squealing
  48. 03 Neon SE fuel gauge and speedometer no longer working
  49. camber
  50. Difference between 2005 SXT & SE & RT ?
  51. Vibration w/ no steering problems; ideas?
  52. any ideas? 05 neon
  53. About time to replace the timing belt
  54. Black cloth
  55. 2002 neon clutch
  56. 2000 ply. neon automatic issue
  57. blown head gasket
  58. 2003 SE upgrade possibilities....
  59. 2000 neon
  60. 2000 Neon, Dies when left alone for 12+ hours
  61. 03 neon sxt needs clutch what parts do i need?
  62. Buy Neon with new coolant system?
  63. new to the forum
  64. cheapest and easiest engine upgrade swap
  65. Wheel bearing issue!
  66. Urgent! Need some serios help.
  67. head swap 2.0 to srt-4
  68. Build project coming up soon
  69. Frequent Hard Start problem - Please see video -
  70. Alternator Questions
  71. automatic transmission swap
  72. A little imaganation
  73. Requesting "Viper" style front bumper pics.
  74. LED taillight/reverse light bulb replacement
  75. HID Headlilght Conversion Kits
  76. 2005 Sxt Struts sound like they are going to come through the hood
  77. 05 sxt auto overheating
  78. Trumpet horn
  79. Where to buy fog lights?
  80. fires but wont stay running
  81. 2000 neon auto transmission problems
  82. 2002 neon shakes at highway speed
  83. Do I need to replace coolant?
  84. cold startup grind
  85. water in the floor
  86. Help !!! How do I get the connector off the alternator ??
  87. 05 neon sxt missfire in no. 1 cyl.
  88. Need injector help 02 sohc
  89. need some advice.
  90. 2000 neon error code 0743
  91. Battery Light on a 01 Neon
  92. how to replace motor? 04 sxt 2.0 sohc
  93. P0700 code and more..
  94. wipers stopped working
  95. 2.0 head help
  96. 2005 sxt stalls after it warm s up
  97. what do you think
  98. Idle Undershoot Issues
  99. 03 neon sxt 5 speed tach goes up but slow aceleration??
  100. Exhaust System Opinions
  101. '03 neon sxt parking brake
  102. Cam Position Code Help Needed
  103. Climbing Idle after spark plug change?
  104. 2002 dodge neon heater issues
  105. Very bad noises/movements after curb check. Please help!
  106. P0448 engine code for 2000 Neon
  107. lost keys!
  108. Water Pump Problem
  109. headlights
  110. bad oil pressure sensor
  111. Bad oil pressure sensor
  112. quarter million
  113. Hard downshift from 2nd to 1st gear?!??
  114. Radiator fan problem 2003 SXT
  115. 2005 SX2.0 (Neon-like?) light problem
  116. neon problems!!! plz help!!!
  117. broken washer nozzle
  118. HELP!! What is your TPS Volt. @ idle?
  119. Three, Five, Three, Five, Three, Five
  120. Why Does My Neon Run With The Cam Sensor UnPlugged???
  121. downpipe
  122. Finally! Pics of my Neon
  123. Rebuilding turbo
  124. Transmission mount 03 SXT
  125. Chip or no chip
  126. Replaced PCV valve, oil sensor switch, oil still leaks, what should i check next
  127. transmission interchangeability
  128. OBD Code Question
  129. 2001 Neon runs good cold and spits / misses when warm
  130. 2001 Tranny swap
  131. SRT-4 Spoiler for sale
  132. engine swap
  133. Makes loud noise when in idle-acceleration. Please help.
  134. timing belt
  135. timing problem
  136. Good website for parts?
  137. Engine oil and Auto. Transmission leak?
  138. 2000 Neon PCM replace, need flashed?
  139. Suspension Problem
  140. Hesitation issues when warm
  141. 2000 Neon, Cranks but no start, no spark
  142. 2004 Dodge Neon SXT Shifting Problem
  143. To fix or not to fix?
  144. 05 Neon SXT- Vibration/Shaking
  145. 2001 r/t cold start issue
  146. Reinventing the Neons PCV system
  147. back up and defroster problem
  148. Fog Lights
  149. Car won't run after rebuilt head/new cam sensor
  150. 2002 dodge neon po755 code
  151. Sporadic limp mode
  152. help little bit water
  153. 03 automatic transmission problem
  154. Need some help
  155. Rear Disc Conversion
  156. knocking noise at idle.
  157. Greetings from UK - Neon Problem
  158. Exhaust rocker 2000 2.0
  159. Should I have also replaced my belt tensioner?
  160. oil overfill...(did i just screw myself?)
  161. Strut replacement issue
  162. catalytic question
  163. Another Timing Belt Question
  164. Transmission Problems in GF's Car
  165. Bad Shaking or Vibrating While At Idle?
  166. Issues and questions
  167. Changing fron door speakers / how to remove door panel
  168. Swapping out for an aftermarket exhast muffler
  169. o132 code '03 neon sxt
  170. Air filter box and headlight question
  171. Grinding noise coming from the exhaust
  172. Rear speakers only work when it is 100deg+ outside!!!
  173. Electrical Issues - Headlight, Tail light & interior lights
  174. front Brake Rotor Crystallized??
  175. Whole car and steering wheel vibration
  176. 2000 neon oil pump R&R
  177. Reverse gear won't work when cold
  178. Overheating
  179. SRT-4 Suspension for 2nd Gen
  180. Yet more vibration problems.
  181. 04 Dodge Neon Problem
  182. torque converter clutch selenoid
  183. Blocked Cat or Bad Fuel Pump
  184. Replaced both O2 sensors, still getting codes.
  185. Heater problems...
  186. bigger spark plug wires?
  187. How to 2004 LSD swap a 2gn neon?
  188. Normai oil pressure
  189. Power Deck lid Latch Installation
  190. ebrake auto engage?
  191. 3rd plug cylinder
  192. E-Brake Stuck or Slow to Disengage?
  193. After accident problem
  194. Oil Leak
  195. Automatic Transmission Problem..
  196. p0700 code
  197. Tell me about the neon
  198. Dome light issues
  199. 02 SE to 03+ Front End Swap
  200. Rain
  201. water in transmission??
  202. dodge neon acr exaust
  203. PCM Update
  204. exhaust smoking on start up
  205. transmission swap
  206. Help neon will not start!!!
  207. 2002 Neon SXT Transmission issue
  208. Dodge SX 2.0 and dodge Neon
  209. Selling 4 Srt4 factory rims with tires
  210. Fuel Injectors
  211. Car sputters on acceleration
  212. 03 Neon automatic Trans issue
  213. Transmission fluid level
  214. Electrical Problemz
  215. need names for these bumper parts...
  216. steering column replacement
  217. 2003 neon
  218. What would be the steps in changing out motor mounts?
  219. 2005 SXT code p 0420
  220. CKP/CMP sensor tests
  221. Its getting worse(noise)
  222. broke hose connected to throttle body not sure what its called
  223. Losing oil
  224. 2000 neon 1st gen swap or srt4 swap
  225. Siliconed taillights and still have a wet trunk
  226. Help wiring new headlights!
  227. Normal operating Temperature???
  228. Heater Problems Please Help!
  229. power steering feedback question...
  230. Need an 03 Neon Rim
  231. Mtx trans removal and repair
  232. neon accident HELP
  233. 02-03 Front Bumper Swap???
  234. 2003 Dodge Neon Sxt Battery Light (SO MUCH HELP NEEDED)
  235. broken reverse.
  236. 01 noen engine problem PLEASE HELP!
  237. 2001 Dodge Neon Blown Cylinder? Need Help.
  238. 2003 Neon SE Power window/lock conversion help
  239. Lightning Bolt warning light on Dash
  240. Help me clean my garage out
  241. 2003 neon sxt stuck in 2nd gear
  242. Highbeams wont turn off?
  243. Door Lock latch/actuator
  244. LEV Catalytic Converter 02 Neon R/T (PIC)
  245. 2000 Dodge Neon Vibration
  246. Power door lock problem 2000 Neon
  247. 2002 dodge neon accelerator problem
  248. Dodge Neon 2004 SXT 2.0L - P0700 Code
  249. headlight wiring harness
  250. what does this mean?
