View Full Version : 2nd Gen Neon
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35
  1. RPMs...
  2. halo headlights
  3. Upgrade Suggestions?
  4. What is this thing on right side of engine where oil is leaking?
  5. Dodge 2003 SXT Bad Mileage per Gallon(MPG)
  6. 2003 Neon Sunvisor Support/Latch Wanted
  7. shifting
  8. Anyone know how to smoke tail lights like this
  9. Need to know of Delphi fuel pump is good quality
  10. NVLD pump
  11. Is it worth it?
  12. 2002 Neon motor mounts + other ?'s
  13. Discount Dodge parts in Pittsburgh
  14. Power steering pressure switch?
  15. first gen for sale
  16. 2003 Neon problems
  17. 03 Neon Crankshaft seal
  18. Camshaft sensor problem
  19. fuel pump or fuel pressure regulator?
  20. Needing parts for my 2003 SE
  21. Parting out my neon
  22. speedometer?
  23. False claim on a catback auction?
  24. 2003 neon sxt evap control problem
  25. a/c issues
  26. engine light and oil light
  27. 2002 Neon Motor Mount Issue
  28. painted 1 gen sport rims
  29. quick question
  30. Hey GUYs Newb here 2001 Neon engine swap
  31. electrical problem
  32. 14" steel wheel valvestem location
  33. Rear drum to disc swap
  34. Foglight fuse keeps blowing!!
  35. 2000 Dodge Neon Glass
  36. Engine light came on and the motor sputtered a little bit when accelerate
  37. Strange fuel issue
  38. 04 Neon SE Magnum R/T intake swap??
  39. Battery power issues?
  40. 2001 Neon: R/T without the magnum engine?
  41. neon noobs axle issue
  42. P0122 (TPS) Issue
  43. 2002 dodge neon complete motor, tranny, harness,cutom turbo
  44. air intake
  45. code 0123 help!!
  46. A quick Shoutout
  47. Alarm/remote start/ keyless entry?
  48. help with motor swap
  49. 2002 Neon squeaking noise from rear left upper strut
  50. Tokico Struts + Rear Sway Bar
  51. Looking for 16" Stock R/T Wheels
  52. Alternator Belt
  53. Coverin a scratch?
  54. lookin for side skirts
  55. Smoke came from steering(lights/signal lever)
  56. Car Hopping
  57. Bright headlight I just replaced
  58. Rear bumper cover help
  59. 2004 Electrical Problem
  60. Fuel Filter replacement
  61. 03 and up headlights on 01?
  62. Trouble with my SX 2.0
  63. Throttle is "hanging"
  64. HELP NEEDED!!! Hella Horn Install
  65. Starting problem?
  66. 01 Dodge neon Throttle/Gas pedal sticking?
  67. 2002 sxt very bad engine or trans vibration
  68. 2001ES computer and Coil pack
  69. headlights 2001 Neon
  70. Parting out 2003 Neon...
  71. Oil in the intake manafold??
  72. sidewall damage.
  73. not very knowledgable
  74. Parting out 2005 Dodge Neon
  75. So I've changed my mind...
  76. 2005 stock SRT-4 exhaust for sale
  77. 2004 Neon Stock speakers
  78. Dodge Neon 03 fuel gauge problem
  79. 2004 neon rear shocks
  80. 2002 Neon Hard down shift
  81. electrical problem - PLEASE help
  82. 2nd gen export tails 4 sale
  83. wires causing interference?
  84. Dodge Neon EURO lights for sale on ebay
  85. HELP!! 05 Neon SXT Trans Leaking and overheating.
  86. darthroush
  87. cylinder head
  88. Which is one is BETTER
  89. P0341 plz help guyz im stumped...
  90. Slipping transmission and leaking coolant
  91. Help with code P2096....
  92. Transmission Noise/Half shaft replacement
  93. need help with head gasket replacement
  94. removing the rear seat back
  95. Blend Door
  96. Picked up another neon...
  97. What can i do with 2001 Neon ES??
  98. 2003 Dodge Neon SXT Total Electrical Failure
  99. Manual transmission swap
  100. Mud Flaps
  101. Hey Everybody
  102. cooling system ?.. thermostat and fans...
  103. Low Fuel Psi Problem
  104. Can somebody please quickly tell me where this grounding strap goes?
  105. need a 5 speed transmision
  106. Timing belt questions for a low mileage 2000 neon
  107. lowering the neon
  108. anyone seen this???(240 mpg)
  109. What other gauges?
  110. Been a long time
  111. Been a long time
  112. ac not blowing as hard
  113. help need tranny for 02
  114. 2001 Timing belt/Water Pump
  115. crank no start p0016
  116. Check engine light!!!
  117. 05 Neon Shifting
  118. detailed stereo installation?
  119. This car is really ticking me off,please help me!
  120. Oil Light ?
  121. water pump leaking... need advise!!!
  122. what all will this engine fit?
  123. 03 Neon SXT basic maintenance/mods
  124. 2.4DOHC swap into my 05 sxt auto...what do i need to make it happen?
  125. 02 transmission problems
  126. Got fuel related problems.
  127. new 2003 neon owner and problems
  128. Neon won't shift?!?!?!?!
  129. New neon owner
  130. brake time!
  131. Side Skirts
  132. removing boots on neon 05
  133. Emergency Brake Frozen
  134. SXT '05 Black Neon Front Bumper...
  135. 2000 Neon Transmission
  136. 03 Neon 2.0L Water Pump Brand Recommendation
  137. Bad vibrations
  138. 01 neon wont start.....HELP!!!!!!!
  139. 2000 Neon keeps tripping fuses
  140. Lower Class Club
  141. ATX trans will not downshift on it's own.
  142. bmw m3 vs, just a neon???
  143. 2002 Neon Rear Brake check
  144. Axle whench size
  145. Brand New Prothane Motor Mount Inserts For Sale! [Street Version]
  146. Parts Interchange info for 2001 Neon PLease
  147. side skirts..
  148. Need help with 2001 ES
  149. 2000 neon fuel pump
  150. OEM Neon Wheels
  151. what the neon looks like
  152. theft alarm light stay on ?......
  153. pcv valve 2000 neon
  154. srt4 instrument cluster
  155. park light bulbs?
  156. How do you take the bumpers off?
  157. Desperate please help with skim module
  158. 2003 SX 2.0 Help and Please tell me I just didn't make a huge mistake
  159. Buying SRT Spoiler! $125!
  160. wistleing every time i step on the gas..
  161. Fah-Ken Kawps
  162. transmission problems
  163. DPredator
  164. ac compressor oil
  165. transmission rebuild kit
  166. 2005 Dodge neon sxt will not start. Lights and everything work good, but when the key
  167. CAI Exploded
  168. Low Brake Pressure
  169. Hardware help!
  170. Easiest/Best way to remove door latch
  171. Let it be quiet again!
  172. 2000 sohc head, anyone have one for sale?
  173. Does my neon have a transmission drain plug?
  174. 2000 dodge neon wont shut off
  175. Vote my dog cute!
  176. Minor problem (please help) 2000 es.
  177. Code 0440
  178. Bigger fuel rail and injectors needed for my 60MM TB?
  179. quick question: how to install cd player
  180. horn help
  181. Automatic Transmission Reliability
  182. diagnostic tools
  183. rear speker trouble 2001 neon
  184. big spoiler?
  185. wiring problem?
  186. things to look for when buying used?
  187. Timing belt how to.. Anyone have.....
  188. 6 cyclinder fit in Neon??
  189. Power door locks
  190. 2004 SXT (15-17 MPGs)
  191. Premium or regular unleaded?
  192. Transmission sounds?
  193. Squeaky rear brakes
  194. Alternator Switch
  195. Help on 2000 dodge neon
  196. Transmission Issue (Codes P0700, P0731, P0755)
  197. sideskirts are installed
  198. Im back with pics of my neon and a new attitude!
  199. What do you think of my neon?
  200. please help...2001 neon Mis-Fire.
  201. Air bag suspension
  202. Turbo a R/T 2004 neon what do i need
  203. going with a new look for the neon
  204. What Altezza's?
  205. 96 head on 01
  206. Front seat belt adjuster thing
  207. Snap ring?
  208. cam sensor
  209. troule code??
  210. I'm staying...
  211. Used parts
  212. Whats the word on these tires
  213. how my car died and if I can swap the power locks etc
  214. Just got my tokico's & sportlines on. a few pics inside.
  215. Will a turbo Work with my automatic tranny?
  216. will a clutch out of a 95 fit a 2000 neon
  217. MPG Problems
  218. Odd problem with cable clutch/Pedal
  219. Front suspension noises??
  220. 00Neon89's Turbo questions
  221. bumper hits the road....
  222. wheel torque?
  223. contagious for sale thread
  224. Dome light stays on.
  225. cooling fans
  226. 2002 SE transmission
  227. P0441 Bad ECM ???
  228. Parts to get rid of
  229. great day
  230. tires on neon
  231. need parts
  232. car won't start
  233. large evap leak detected
  234. automatic tensioner for 2002 dodge neon
  235. Dodge Neon Steering Wheel Swap
  236. Cams
  237. 2nd gen TURBO neon
  238. Suspension Info
  239. i hate to brag, well not really!
  240. Wheels..
  241. runnung lean?
  242. SRT4 Strut Bar fitment on Neon
  243. raceing dodge neons lol
  244. Pick me out a system..
  245. Neon T drop
  246. Neon is no more...for now
  247. Awd
  248. lost all electical power
  249. sqeeky suspension
  250. Brake Pads - "Export" vs. "Not Export"
