- 98 Avenger Keyless Entry
- engine fuse keeps blowing
- Hi Everyone
- '98 ES 2.5l smokes, yet no trouble lights...
- fuel problem
- 1998 Avenger ES Engine shot??
- I Guess This is Goodbye
- Got a spare $30K ???
- transmission upgrade
- nnewbie needs help
- Slight squeal and smoke from near p.s. pump on 2.5L V6
- breaking transmissions
- 2.5L engine noise
- 2000 dodge avenger alarm
- DIY Post on Replacing Door Handles?!?!
- Possible Interior Alteration?????
- Accesorry Belt Tensioner Pulley bolt
- overheating...
- For Sale: 1995 Avenger
- 1995 Avenger Computer Interchangable
- 98 Venge Question
- 1995 Dodge Avenger Just Dies
- Wife's avenger is frying throttle cables...
- GB: V6 95-00 Avenger/Sebring Leightweight Crank Pulley
- 98 dodge avenger.. 2.5 liter fast?
- In need of hood & front bumper
- P0134 issues after 02 replacement
- Tranny swap questions
- Overheating issue...
- 1997 2.5L transmission wont shift into overdrive.
- '96 V6 ES Avenger Engine
- 97 es > top end is knocking and ball joint recall no longer good!! ChryCo is crap!
- 99 aveneger trans problems
- D@mn multiple misfire code !!!
- 98 transmission problem
- 96 Avenger has a mind of it's own
- 95 2.5L and seafoam
- possible fuel pump??
- 99 avenger 2.5 6g73 NEED HELP!!!
- Interesting Tidbit...
- first post
- car jerking
- A604 Transmission Solenoid...
- parting out 97 es
- fuse box problems
- 1997 2.5L idle problem.
- Suspected grounding problem?
- How to remove black specs on 2.5L intake manifold?
- help with noise
- 98 Avenger replace tweeters
- how much horsepower can a 41TE automatic tranny handle?
- Radio Problem
- Where is the output speed sensor.....
- 96 Avenger won't start
- Multiple problems.....
- Recommended Tire pressure for 98 avenger?
- Dodge Stratus r/t 3.0L intake manifold on 2.5L?
- Dont think my 97 avenger shifts into overdrive
- 97 avenger makes clicking noise?
- Disturbing Motorsport CAUTION!!!!
- What the f#%@!!!
- Factory Fogs on with parking lights? How?
- Rear Speed Sensor?
- Brake Rotors removal help
- 99 avenger No Power locks? Only 2 speakers work?
- Crank sensor removal '97
- Help wont pass e_check
- A/C Bypass pulley...?
- New to Manual
- 98 Avenger - Please help?
- top middle dash(defrost,hazards,etc)
- '97 2.5L - oil in spark plug tubes?
- where to find complete axle for pass side
- PLEASE help I'm so frustrated...
- '97 avenger 6 cyl no power
- 3.5L manifold on 2.5L and cost of DMsports 5 speed?
- trans wont shift
- what sensor is this?
- 96 venger 2.0 alternator
- 1996 Avenger Brakes
- Aftermarket ECM...or Reprogramming?
- supercharge/turbo 2.5L v6
- what seats fit in a 99 venge? weather strip
- That darn P0740 code....!!
- Condom
- Need a drive belt Idler Pulley!
- Front Brake locks up
- A turbo 97 Avenger
- Need your vote ...
- Hello and Good Day
- 97 v6 venge horn prob
- idle problems
- Car shakes and vibrates
- White smoke/burning oil
- Major issues, please help!!!
- 96 Venge Revving Low at stops?
- Heater panel lights
- 1998 dodge avenger ES spker
- transmission surge-jerk-slip
- Someone help.. Oil Pan
- Cruise Control
- 99avenger check engine light/misfire?
- New Avenger: love it or hate it?
- Driver window sealing problem
- engine trouble......
- New wheels......
- Rough Idle and difficult to start on humid,moist, or wet mornings and when it rains.
- '95 ecm issues
- Radiator Prob......
- trans fluid pan bolts stripped
- 95 ES, TireAir lbs/Alarm
- Turbo ready 420A...What all do I need?
- Help Need a new Bumper
- Avenger transmission fluid
- Idler Pully tensioner bolt
- 97 avenger runs like crap and ticking after new trans!
- Smells like burnin...
- Locking up in reverse only?
- Passenger airbag cover peeling
- '98 Avenger Front End Shaking
- srt-4 motor
- '96 Avenger 2.0 won't start, help!
- 98 Avenger Electrical Issues
- 41TE transmission help
- 98 Avenger P0304
- 1995 Avenger 2.0
- Help with Avenger Starting Issues.
- Bad Venge OR Silver...I need your help!
- 98 Avenger stalling
- Smash Bang Crash
- 1996 avenger ES High oil pressure issue?
- Reliability/Repairs Questions
- Engine stumbles then turns off
- Exhaust Manifold
- squealing
- Need help!!
- Spoiler bolts?
- Overheating with ac
- Turning Noise
- V6 To I4
- Black tar coming from behind door panel...
- a/c belt help
- 97 2.5 ES throttle lag issue...
- Idler Pully Issue
- aftermarket crank pulley question
- Gauging Intrest Racing seats ready to bolt in
- What is pictured here???
- V6 timing belt question.
- O2 sensor question...
- convertion
- Removing back deck on 96 venge
- 98 ES 2.5 V6 Idle Surging Code P0122 Low TPS Voltage
- 95 Venge 2.5l Stalling issue....
- Over Charging???
- Fuel Rail Bushings/Spacers?
- I keep blowing a fuse
- lock/unlock door 1997 es 2.5
- car shutting off
- Tranny Issues?!?!
- p0300 code yet running fine..HELP....
- Starter on 2.5
- A604 Trans Valve Body
- A few questions about the sound system.
- Need help with o2 sensor location...p0134
- 97 Dodge Avenger whine
- 97 Avenger is leaking.
- Help!! Tranny!!
- Going to possibly purchase another venge.....
- cherry bomb glasspack
- Trunk and license plate lghts not working
- Avenger/Sebring ECM
- sticky e-brake on '95 avenger sport
- Photobucket pics of my Avenger
- replacing alternator plz help
- 1998 2.5 Avenger ES
- Simple question
- 98 venge door lock problem
- no spark 97 avenger
- Help with 98 Avenger
- A/C Not working
- K CEL acting.....weird
- What Now?
- throttle cable looks loose?
- Oil Pressure
- Cruise Control
- SCREEECH! Possible A/C issue
- After sitting 2 months, loud squeal?
- Planning On buying 98'venge As First Car- Some Questions
- Power Steering Pressure Switch
- 4x12s???
- Alternator Help?!
- 1995 Avenger still having issues
- Need help with Code P0301
- Felco 255LPH Fuel Pump
- Lambo Doors
- SRT-4 engine swap
- Any A/C repair guys out there?
- Fog Lights
- EGR insufficient flow detected
- Pos & Neg Battery Cable
- What are the specs on the factory infinity system?
- Damp Engine?
- Tranny help again....
- Where Do I find Engine Code?
- 99 Avenger Tranny Arms
- Avenger Infinity Amplifier Fuse?
- Need your opinion, please
- Need help with 1995 avenger
- Speaker questions.....
- CEL and other fun.
- Clear front corner lenses
- New CEL code
- Control Arm and Tie Bar
- Tranny swap: Eclipse to Avenger
- Best sounding muffler for 2000 avenger
- Speaker mounting brackets??
- Suspension question
- Oops ... I broke a hose ...
- Oxygen Sensors
- Trouble turning over..
- Roaring Noise
- Aftermarket HD ball joints
- Trans/General question
- Quick question
- Engine buildup: 4 vs. 6 cyl
- Little tranny question/problem??
- just returned from Dodge Dealership
- New 1999 Dodge Avenger... now what?
- Hi guys need a water pump???
- sunvisor lights
- ECU Pinout?
- Oil pump replacement do's/dont's
- new to site and some questions
- Was It Worth Fixing??
- Lowering Coil Springs
- Manual tranny fitment on the v-6?? Possible??
- Transmission wont go into reverse why?
- Rough Ride
- Brake light switch????
- Timing Belt Replacement 1999 v6
- Avenger v8 rear wheel drive?
- how to install a msd in my 98 dodge avenger
- Check Engine Light Stays On- Need Help Please
- Why may my car be dying?
- Forced induction v-6?????
- Avenger Stalling issue Code help please
- Engine swappin...
- antenna adapter needed???
- engine shaking, rough idle?
- Well, I'm learning a little more
