View Full Version : Dodge Cummins Diesel
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49
  1. Rim size
  2. Need Help
  3. 2wd lift kit needed.
  4. What to look for in a used Cummins powered Ram?
  5. Opinions greatly appreciated
  6. Cummins Club
  7. removing resonator?
  8. flashpaq vs smarty jr
  9. Help!!
  10. How long did your batteries last?
  11. break in time on the new 6.7??
  12. Weight?
  13. upgrade to cummins
  14. Intermittant Radio
  15. ATS trans...anyone have one?
  16. i need to increase my mpg!!!!!!
  17. removeing the dpf on 6.7 cummins
  18. on the dyno
  19. Low Idle
  20. 01 Cummins 3500 Acceleration Problem
  21. 02 2500 intermittent starting
  22. Boost
  23. 4bt cummins.
  24. Where is the water coming from?
  25. what engine oil does everyone use
  26. Transfer Case Will Not Stay In 4WD
  27. just bought a 2001 ram diesel, questions!!
  28. Just bought a 2005 Ram 2500 with a Edge juice with attitude performance chip
  29. steering gear box
  30. best lift kit
  31. 5.9 2006 2500?
  32. info needed oem exhust for a 2003 3500 dually
  33. New to CTDs and loving it.. but looking for advice
  34. fuel shut-off solenoid not engaging?
  35. Need Help!!
  36. How to Determine Rear Axle Ratio on Used Trucks
  37. 2008 6.7l engine knock
  38. rear drive shaft support bearing
  39. I suspect a turbo. Looking for opinions.
  40. 07 6.7 Engine oil
  41. Cummins engines for sale
  42. 5.9 diesel
  43. What's wrong with my '06 Cummins? fuel related
  44. What's wrong with my '06 Cummins? fuel related
  45. 2500 RPM Boost Loss
  46. Steering Dampner Removal (HELP!!)
  47. $200 Rebate on Pioneer Navigation [Holiday Rebate]
  48. big head wastegate
  49. DIY Heater Control Bulb replacement
  50. Need exhaust advice for my 07 Cummins
  51. Left rear axle seal leaking?
  52. Grab handle
  53. AA axle or not?
  54. Digital Monitors / Gauges
  55. What is the difference between 305/325 cummins.
  56. Leaking Transmission?
  57. straight pipe
  58. Programmers/tuners
  59. 99 2500 cummins fuel filter canister leaking fuel
  60. 2004 Ram 2500 5.9 Speedo Cluster Swap
  61. Diesel injector pump
  62. clicking when starting?plenty battery
  63. 2004.5 throttle problems
  64. 12V lift pump or turbo?
  65. Need help with a oil control problem
  66. P1755
  67. 2008 dodge ram vibration-off accerator
  68. Fuel sending unit
  69. engine light came on
  70. 2004 Motor Trend Diesel Comparison
  71. Getting first diesel, few questions.
  72. diesel info
  73. Pioneer releases FREE iPhone App [demo video]
  74. Face Lift for my Truck
  75. 03 cummins turbo question....
  76. New 6.7l Service
  77. 2004 ram 2500 diesel
  78. fast idle on a 5.9
  79. My First Cummins w/ PIC!! Few ???'s
  80. Edge and Codes
  81. How often does your 6.7 regen?
  82. Weird Shifts
  83. California!!!
  84. 2010
  85. Storm Chasers/TIV 2
  86. Tire Rotation
  87. Gearing question.
  88. levelling kit 02
  89. ISO: 2005 2500 Ram Service Manual
  90. Shopping/5.9L Facts?
  91. newbie questions 2002 ram 2500 with a cummins
  92. Dash almost burst into flames.....
  93. spicer 70 3.55's play in rear in yoke
  94. brake upgrades
  95. superchips flashpaq
  96. Stop the miles from going on ur truck?
  97. Tomorrow's the big day
  98. Knocking when you let out the clutch
  99. Front end shaking when i hit a bump
  100. 5.9 vs 6.7
  101. remote start on 12 valve
  102. how to disable SKIM/Immobilizer ??
  103. Cummins, Idleing rough?
  104. Question about Thermocouple Wire Length
  105. First time putting Antifreeze in my 94
  106. If its not one thing its another - Horn stuck
  107. PSM air intakes
  108. Anyone recommend the best brake controller for a 2003 CTD?
  109. Break In
  110. water leaking from grab handle
  111. SuperChips stack with TS Performance MP-8
  112. fs 2500 bypass oil filter ?
  113. fs 2500 bypass oil filter
  114. Transmission ??
  115. Blocking Cold Air
  116. need pyramid shaped spring for shift shaft on 93 manual 4x4?
  117. dept of transportation check point
  118. headlights not working
  119. Bypassing the Cats on an 08 3500
  120. Questions before buying a cummins
  121. Thinking of buying
  122. Looking at Diesels - Advice?
  123. 2 cycle oil in bulk
  124. !! You should see it !!
  125. Turbo Issues
  126. will 35's fit on stock 2500 diesel
  127. Diesel shopping need advice, what to buy, auxiliary tank...
  128. Which Exhaust?
  129. Problem with towing harness - Cummins diesel
  130. cruise not working
  131. Hx35
  132. 2007 5.9 CTD Strange Noises
  133. New Owner
  134. Caster information
  135. Nitto Trail Grappler M/T *New Sizes Released*
  136. Code P0088
  137. Fuel gauge
  138. Ram diesel Engine/Cabin heater
  139. Joining the CEL Brotherhood!!!!!!
  140. Strange overhead console problem
  141. Pull rotor without pulling wheel bearing???
  142. 2004 2004.5 question
  143. weird question
  144. MileageHowToIncrease?
  145. won't start by itself
  146. Noob w few q's
  147. Check Engine Light blinks 10 times, three others lights not illuminating
  148. Wierd problem. Tranny, diff, or computer?
  149. 04 CTD won't start
  150. just bought a 2008, mega cab, cummings
  151. Strange 6.7 problem
  152. transfer case needs rebuilt!!...help?
  153. Front end problems
  154. Fuel Sending Unit problem
  155. transmission problems
  156. My first Black smoke, boy is that addictive...
  157. 35" rims and tires forsale
  158. Valve Lash
  159. 6.7 08 Ram CTD 2500-Lost instant power & wont spin tyres anymore .Help?
  160. no oil pressure
  161. Runs sluggish til warm
  162. changing rear brakes/wheel cyl
  163. Recomend 35" tires that are good in the snow
  164. Diesel for 1500 Ram
  165. AFE Stage II question
  166. injectors
  167. HELP: my Injectors are Destroyed I NEED NEW INJECTORS!
  168. new lights tell me what you think
  169. Looking for less black smoke!
  170. 33" Tire Recommendation
  171. best warranty?
  172. buying advice
  173. Fuel filter questions
  174. 99 Straight Pipe?
  175. 3 different diesel engines in 2004?
  176. Let her smoke
  177. O7 3500 ram with 200k miles on it
  178. anyone ever change spark plugs and wires on their 5.9???
  179. injector crossover tubes
  180. 03' Dodge Ram 3500 CumminsTD, Max Tire Size (stock), and lift questions?
  181. lifted truck and towing questions...
  182. Has anyone had to hire an attorney to fight Chrysler
  183. injectors?
  184. Truck doing weird things....
  185. Head gasket leaking
  186. cr vs mechanical injection
  187. new place to hang my hat
  188. Wastegate/actuator failing?
  189. Rumor or true??
  190. motor measurements
  191. just got loud
  192. Vacuum pump oil leak!!!!!!!!
  193. Help!!! Got a problem withmy tranny
  194. Transmission Troubles
  195. 19.5 or 20.5 inch wheels
  196. NEW 6.7 Powerstroke!!!
  197. Programmer?
  198. looking at my first CTD, what to look for?
  199. Nitto Tire Launches a New Interactive Site for Trail Grappler M/T (check it out.)
  200. RPM jumping between 40 and 50 mph HELP
  201. Towing Weight
  202. 2007 6.7 exhaust question
  203. Dyno & Racing at Silver Dollar Raceway
  204. Time for Tires
  205. fuel sending unit issue
  206. Poor Acceleration
  207. first generation injectors
  208. Was there a SLT Laramie Reg Cab 2500?
  209. Transmission help needed
  210. Leaking Tranny Cooler Lines
  211. 2500 4X4 rough ride
  212. gauges vs. digital dash displays
  213. 02 cummins exhaust
  214. A/C compressor clutch problem??? Need help ASAP
  215. Weird squeak
  216. Alternate method for front U-joint lubrication?
  217. Sluggishness fixed!!!!
  218. Injector pump / fuel pump
  219. How many fuel filters on 06' 5.9 Cummins
  220. 98 Dodge Turbo Hose Blows Off!!
  221. Differential & Tranny fluid
  222. 5.9 front u joints
  223. 99 dodge 3500 died while driving...
  224. HI-RES Nitto Dodge Ram Desktop Wallpaper [free download]
  225. engine block cracked
  226. my ram
  227. What is the real cost to drive?
  228. It just shut down help !!!!!
  229. a/c stopped working
  230. fuel problem
  231. truck wont start
  232. 2010 Dodge Ram Diesel
  233. Transmission Problemmo
  234. "chipped" engines - good, bad, ugly???
  235. Looking to buy - have some Qs about the 2006 vs older models
  236. Fuel MPG of stock 5.9 vs 6.7
  237. P 2850
  238. No power to sending unit/lift pump?
  239. 6.7 fuel in oil
  240. Which is the better early Cummins
  241. 2006 Dodge 3500 Diesel mega cab trans probs
  242. HO????
  243. remote oil filter
  244. 2004 1/2 HO Diesel help!
  245. 2005 Dodge Ram Transmission Shifting funny
  246. Hard to start, can't figure it out ...
  247. 99 RAM Diesel Help?
  248. new to site and question please??????
  249. How do you tell if a cummins is common rail?
  250. remote oil filter system
