View Full Version : 1st Gen Intrepid
Pages : [1] 2
  1. Heater Core
  2. 97 Intrepid MAP Sensor location
  3. 94 Intrepid with 12" Sub and Amp suddenly doesn't work..
  4. help with my car
  5. wierd clonking
  6. New water pump but wont start
  7. upper cylinder rattle
  8. 1G Intrepid - No reference voltage at crank and cam sensors??!
  9. 1996 3.3L Crank Pulley Removal Leaking Oil
  10. 95 intrepid wipers wont work
  11. Gauges, digital climate, overhead compass stopped working =[
  12. 1996 Intrepid won't shift out of first gear! Check engine light on! HELP!
  13. 1996 Intrepid won't shift out of first gear! Check engine light on! HELP!
  14. 1g Trepid - Ran Fine Last Week, Wont Start This Week, log of progress
  15. Transmission Control Module
  16. 1st Gen Factory Service Manual
  17. OBD 2 Reader
  18. 1996 Dodge Intrepid
  19. 1997 Intrepid smoking
  20. BCM or PCM???
  21. Speaker wiring
  22. Body control module??
  23. 1996 Intrepid Code
  24. 98 SE Alternator removal help
  25. The rebbuild of a 1997 Dodge Intrepid
  26. Wiper only works proper on high
  27. 1997 dodge intrepid fuel pump problems
  28. 1997 dodge intrepid fuel pump problems
  29. 1997 intrepid missfire
  30. Crank/Cam sensor help
  31. Gauges
  32. TSB 02-16-99/'95 interpid pulls hard right
  33. Brake lines busted
  34. Intrepid won't run. Possible electrical problem or pcm?
  35. Intrepid problem with stalling
  36. Problem with Wipers/Turn Signals/Radio
  37. Noisy rear strut mounts
  38. Used parts
  39. No start but have power??
  40. Hey from BC Newby
  41. 1996 intrepid rear brake line size?
  42. Turn Signals Don't Flash...HELP please
  43. AC question
  44. Transmission Problem, Please Help
  45. Solenoid Pack
  46. Parts car 1996 3.5l interpid
  47. 1995 Intrepid OBD I
  48. I've been gone
  49. replaced tranny
  50. 93 intrepid doesn't shift past 1st gear, help please?
  51. 94 Intrepid Stalling Issues...
  52. high idle
  53. Engine removal replacement 3.5 '97 Intrep
  54. 96 Intrepid Gauges Not Working
  55. Instrument Cluster
  56. High Idle
  57. Intrepid went crazy
  58. 94 Intrepid Rotor Specs
  59. 1996 Dodge Intrepid
  60. 95 intrepid bounces like a boat over bumps ?
  61. Help on a 1995 dodge intrepid
  62. Broken Intake/Head Bolt
  63. Need Help Plz! 95 dodge intrepid wont turnover
  64. 97 Intrepid will not start
  65. 97 Intrepid Help Required
  66. help
  67. 97 intrepid trouble
  68. The ol' Intrepid getting there
  69. 97 Intrepid Dash lights/rear lights out
  70. Changing plug wires on 95 intrepid 3.5L
  71. Help, shift problems
  72. Dodge Intrepid, No Spark, No Fuel. 1995 3.3L
  73. How much longer do you think it will last?
  74. 1997 dodge intrepid no ignition power
  75. 1997 Dodge Intrepid Won't Cold Start
  76. 1994 eagle vision 3.3 tranny 2 questions
  77. Car and truck of the year voting NOW
  78. '94 Dodge Intrepid (3.3) Timing Belt Broke: Engine Destroyed? $600 only way to know?
  79. Allright this is for you intrepid lovers i need your help
  80. Remote entry fob programming
  81. Engine stopped running while driving
  82. Leak
  83. Oil sensor on 95 intrepid 3.5
  84. 97 Intrepid engine control fuse
  85. 3.3 to 3.5 Engine swap
  86. V6 exhaust
  87. 1997 Intrepid Heater Core
  88. labor time on belt installation
  89. We need an Intrepid Section Moderator
  90. Timing belt replacement on 3.5 v6
  91. Rear Disc Coversion
  92. 1995 Intrepid 3.3L
  93. 94 trans problem please help
  94. 1995 Intrepid help
  95. DF Video!
  96. 1997 intrepid 3.3
  97. 95 Intrepid with OBD-1
  98. sound system upgrade
  99. 1997 Intrepid transmission question
  100. 1997 DODGE INTREPID WON'T START
  101. ecu to tcm wire
  102. replace headlight housing?
  103. help on 93 intrepid es
  104. 3.3 starter help
  105. 95 dodge intrepid guages stopped working!
  106. aftermarket stereo
  107. Driver Side mirror repair
  108. Good Buy? / cost to repair?
  109. a/c
  110. Online parts catalog
  111. a couple annoying things... that I hope is a easy fix?!?
  112. Intrepid tranny issue?
  113. MPG on Intreprid?
  114. 1995 brake problem
  115. 97 Intrepid engine knock/tick
  116. Engine cradle Mounts - great price!
  117. Dodge Intrepid engine leaning back
  118. Engine Vibration and Stutter????
  119. yup
  120. 96 dodge intrepid no spark
  121. starts sometimes
  122. Help 1996 Intrepid Motor-Trans
  123. 94 Intrepid intermittent code 51
  124. Electrical issue with '96 trep
  125. 95 tie rod replacement advice
  126. changing oil pump 96 intrepid 3.3
  127. intrepid/vision compatibility?
  128. Heater Steams up windows....
  129. something is draining the battery
  130. 1996 intrepid code 1696
  131. 1996 intripped codes
  132. Apparent electrical problems with my '95 Intrepid
  133. Is it hard to replace wires & plugs on 3.5L 95 Intrepid
  134. Misfiring on accel, no CEL
  135. COTM
  136. 95 washer pump problem
  137. overflow dribble????lol and more
  138. 1997 3.3l Engine -> Timing Belt? Drive Belt?
  139. 95 Intrepid electrical problem
  140. 97 check engine light
  141. battery?
  142. new
  143. 95 Intrepid wiring diagram
  144. 96 3.5 engine swap help needed
  145. overheat after winterizing
  146. engine cradle mounts
  147. 94 Intrepid ES Blower stuck on high
  148. My '97s Governor
  149. dodge intrepid 95engine/ fuse problem
  150. '96 Intrepid pulls right on acceleration
  151. Other Makes
  152. Performance
  153. 95 I Overheateing
  154. Error codes Po401 and Po420 for 96' intrepid
  155. A FEW QUESTIONS (1995)
  156. DWD2 evap cleaner - need help
  157. rich air fuel ratio 97 intrepid 3.5
  158. 96 into 94 engine swap (3.5L)
  159. Odb2 trouble
  160. Might be pickin up a 96 Intrepid, what to look for?
  161. Does a 1994 Eagle Vision TSI have an interference motor?
  162. radiator flush
  163. Tranny flush=eratic symptoms now
  164. Need advice on what to do next. Video clip inside.
  165. 96 intrepid tranny problems ?? HELP !!
  166. remote fob
  167. I changed plugs and now I got an oil light on
  168. 93 ES problems
  169. 3.5 litre crank pulley
  170. Rear axle spindle nut
  171. Fuel Problem On 94 Intrepid w/ 3.3
  172. Help with a 97 Intrepid ES
  173. Need help with a 96 Intrepid ES
  174. steering wheel jumps up and down
  175. ATC diagnostic mode
  176. int. lights
  177. 1997 intrepid wont start
  178. Get out and Vote
  179. 97 fuel system problems, need help!
  180. Intrepid 96 Check Engine Light Codes 45 46
  181. FS: 96 intrepid ES, in PA, needs to go
  182. Fuel Injector Wiring Harness
  183. 97 Intrepid Won't Start, Need Help!
  184. Error code 32
  185. 97 just one low beam works
  186. fast idle 3.5 1995
  187. 97 RKE programming
  188. missfire finally solved
  189. Clunking when stepping on accelerator
  190. interesting wiring issue
  191. A/C help
  192. 1996 eagle vision starting problem
  193. 1994 Intrepid Check Engine Codes
  194. Arizona Residents Unofficial Meeting 5/26/07
  195. detonation
  196. HEATER FAN ON ALL THE TIME!!! HELP PLEASE
  197. Ignition Problem or Something Else
  198. Replacing Fuel Injector
  199. My Dashboard/Transmission are Acting Weird
  200. Fuse that controls horn ('96)
  201. Power window won't roll down.
  202. 95ES Trans/Speedo problem - Help!
  203. 97' Hazards keep going off on their own!!
  204. ram air intake
  205. Philladelphia area dodge owners
  206. Misfiring Cylinder
  207. question
  208. Big Time Screw up!!
  209. Brakes <97' Intrepid>
  210. code 34
  211. fluid capacity?
  212. Racing Tach How do i hook it up????
  213. timing belt
  214. power steering pump and timing (belt/chain)
  215. supercharger
  216. Need help fast
  217. Help Please!
  218. 94 intrepid radio wiring??
  219. Engine ticks loud
  220. Radiator Fans ON All The Time
  221. Code 32, engine miss HELP
  222. 94 3.3L Tranny Problems
  223. 94 Dodge Intrepid
  224. minor problems (maybe) with 97 Intrepid
  225. cd player ?
  226. Cooling fan will not switch off
  227. just bought a 95 intrepid
  228. evap canister purge solenoid noise
  229. Car and Truck of the Month, get involved!!
  230. Intrepid 1st Gen Do It Yourself information
  231. Stalling
  232. 95 dodge intrepid HELP
  233. Heater problems
  234. 1997 Intrepid Cornering Lights
  235. front brakes
  236. as modifications???
  237. headlights and winshield wiper problem
  238. wiper issues
  239. 96 3.8 V6
  240. 3.5 Tranny Questions
  241. Driving without A/C belt
  242. codes 51 and 52 '95 intrepid
  243. code 43 on a 97 intrepid
  244. ABS light
  245. 93 Intrepid Problems
  246. Remote Starter
  247. noob questions on mods
  248. engines seems to shake funny
  249. intrepid headlight
  250. Soldering Wires?
