- Battery Charging problem
- to anyone parting out your trep
- FRUSTERATED stalling
- 98 concorde 3.2
- Should I get new tires or just wait
- P0121
- 2001 intrepid alt. regulator.
- BAD Engine Knock
- intrepidtrouble
- code 301?
- 99 3.2 No Fire
- Abused Ram 4x4s
- 02 Radiator Fan Replacement
- How to get the spark plugs out of a 2.7
- Performance Parts for my 04
- 2.7 cranks but won't start
- Catalytic Converter Discrepency
- 2002 Dodge Intrepid Short Wiring Diagram Help...
- Hepa Filters on a 2000 Dodge Intrepid?
- Gear shifter will not shift into gears, please HELP!
- 2000 dodge intrepid
- Power Steering Fluid Leak
- amplifier problem
- runs sometimes
- headlight adjusting
- starter on a 1998
- Need help 2001 Intrepid
- Sticky shiffter
- P1684?
- NEED HELP!!! New to this forum
- 2000 Intrepid Battery
- 2002 Intrpid: Ignition switch problem?
- Foot brake is stuck! Help!
- My power steering is making loude noise?
- 2000 intrepid blowing fuse
- Rod Bearing Replacement
- 05 stratus
- Radiator Cooling Fans--When do they kick on?
- 98 Intrepid Thermostat
- Code P0138 2004 intrepid
- Body Control Module/Aspirator Motor
- Ford Ranger 16" wheels on Intrepid
- Squealing sound
- 2000 intrepid problem
- antifreeze leak from weep hole at thermostat housing
- Clicking noise during starting?
- What is this crazy sound?
- Blown Head Gasket
- Swapping a 3.2/3.5 inplace of 2.7 ?s.
- 98 Intrepid w/ 3.2 oil leak???
- Question on a Driveline Swap
- just installed new pads and rotors
- 04 Intrepid Rpms fluctuate over 2700 rpm??
- the 2nd gen intrepid dodge should have built!
- 98 Dodge Intrpied Wiring Issues
- P0160 code
- Fan Problem 2002 ES
- Squealing...Please Help!
- air directional/ac-rear defrost buttons
- Changing 98 intrepid driver's side headlight bulb
- 2.7L Turns but won't start...
- Knowledge of Dodge vehicles
- 2.7 alternator and power steering pump can be used on 3.5
- Interior Lights Flashing
- 2002 intrepid turn signal intermittant
- '04 Intrepid antifreeze leak problem
- squeak problem
- Codes and stalling
- Cranks but won't fire
- Electric window switch from driver's door, 2000 Intrepid
- best seal for tranny pan
- 98 Intrepid won't start after rebuild
- Swapped '98 3.2 for '02 2.7... Help!!!
- Are these tries to big??
- 1999 2.7L transmission question
- 3.5l exhaust removal
- Interior light bulb change
- Used parts
- 01 Intrepid Engine Swap
- 04 Intrepid SE, Oil in Cylinder
- Help Please my car has no power
- '00 Intrepid 2.7. ATF Flush?
- dodge intrepid
- How to check codes?
- 2000 Intrepid with bad alternator
- Engine oil smells like gas...
- Need some advice
- any comments on 04 3.5l intrepids?
- 98 Intepid part out
- replacing valve body in dodge intrepid
- Power window
- 99 dodge intrepid programmer
- Sound System Stumper 2
- BCM Question
- 04 3.5 autostick questions
- 1999 Dodge Intrepid for parts!
- 2004 Intrepid - Over Heating
- Replacing 2.7 with a 3.2
- 04 intrepid stalling
- puzzled
- Climate Control display wont stay lit up
- Gasoline smell
- 98 Intrepid Power Issue
- Is it dead?
- 99 intrepid tranny problem
- Frustrated with my '01 2.7
- I've been gone
- Black Housing Twin Halo LED Projector Headlights for 98-04 Dodge Intrepid
- Question
- Immobilzer problems...Pleeez HELP!!!
- stop light anomaly
- Loud Engine Noise
- 2000 Dodge Intrepid knock on startup
- '00 3.2l tranny issues
- Major problem with my friends intrepid
- 2001 Intrepid help
- stumped
- 2004 INTREPID-Check enging light
- New Member
- Oil in front of manifold?
- Help Please.
- noise caused by pulleys.
- 2001 Intrepid stalls when braking from high speeds
- Will a Concorde 2.7 interchange with an Intrepid 2.7?
- Intrepid 2004 2.7L hose/tube broken, help!
- question on 1999 Dodge Intrepid. 3.2 v6
- Electrical issue involving new aftermarkert radio
- torque converter
- 2000 intrepid sunroof
- Newbie- Questions
- Rough starting 3.2
- hey all including kurt2
- 99 dodge intrepid 3.5l For Sale/Part Out
- 3.5l
- 3.5l 215ci intrepid motor problems
- please help ASAP
- A/C control head fuse
- 99 Dodge Intrepid Misfire Problem
- Misfire at Idle
- 04 sxt sluggish engine
- 99' intrepid check engine light
- Jack on Crossmember? Also, Jackstand Locations?
- anyone i need help!!!
- parking lights not going off
- 98 3.2 wont start
- trailer Hitch wires
- 99 Dodge intrepid questions
- Oil Filter Trouble
- 97 - 2000 motor swap
- front speakers
- Power off, whirring sound
- problem removing valve body
- oil leak on 02
- replace 98 intrepid 3.2 waterpump help
- 2003 intrepid power steering problem
- Bypass amp
- 2.7L Oil light flickering
- Oil questions
- Carpart4u.com Projector Headlight Sale!
- electrical problem
- 99 3.2l interpid HELP PLEASE!!
- 1998 Dodge 2.7 Intrepid
- 97 3.5L Intrepid - Starting Problems
- Timing Chain or Tensioner/Guides?
- Will Chevrolet Lumina rims fit Dodge Intrepid bolt pattern?
- 2002 Intrepid transmission problem
- Electrical Problem
- error code P1864
- engine swap..possible? [kind of long]
- 2003 intrepid 2.7 interchange question
- 2000 2.7 electrical problems, HELP!!
- Heat is on or off
- 04 2.7L timing problems
- 2003 intrepid code p0058
- ATC Display; Troubleshooting
- 2.7 Timing tentioner easy change?
- new name same old guy
- 2004 dodge intrepid
- 2000 Dodge Intrepid Problems
- trans wiring harness
- Headrest Removal Help
- change plugs?
- 03 Intrepid SE 3.5L with 3 codes!
- ('02 2.7) Knock sensor
- Water puddle on drivers side floorboard
- Cluster Mileage Question
- 2004 intrepid
- 2.7 p0068
- Door Cupholders?
- 2.7 to 3.2 swap help
- Car and truck of the year voting NOW
- Oil light??
- Shift Solenoid
- 1999 dodge intrepid rear driver side door panel
- 1998 Intrepid Speedometer Tachometer and Odometer
- concorde/intrepid torque converter lockup switch
- 3.2L Nightmere Help!
- Drive cycle
- performance parts
- your cars broke
- 2004 Intrepid- 2.7 rebuild
- Bleeding the ABS
- Please help! buddy's 00 Intrepid won't start
- We need an Intrepid Section Moderator
- 2001 intrepid stall
- Just braggin a bit on my Intrepid...
- Oil Sending Unit....
- 2.7 litre replacement
- Fuel filter is?
- 2004 2.7 litre Intrepid Shift Detent Cable Problem Can anyone tell me how to adjust
- Camshaft Sensor problem.
- 2000 interior lights
- Please help...again
- Which grade of gas to use
- p1684 and p0456 codes in a 01 3.2 trep??
- forgot to remove neg from battery
- limp mode & fuse problem
- need help
- Forged Rods and Pistons
- Won't start...
- stock head unit removal
- 96 intrepid error code p1296
- Security System Problems?
- 2002 intrepid 2.7 engine cost?
- Need 3.2L Rebuilt engine 2000 Intrepid-Recommendations?
- Oil Light Blinks :(
- What is this plate?
- EGR valve
- re use or not the accessories from 2.7 to 3.2 swap conversion 2001 dodge intrepid
- Inside door handle removal
- power window issues
- dead dodge
- spedomoter/mileage meter flameout, check engine light ON...
- How often to change the timing belt and water pump
- Help: Can't remove speaker in middle of dashboard
- Please help!!
- 3.2?
- 2002 intrepid se check engine codes
- lots of transmission code Help!
- p0700 & p0740 help
- Error codes P1684 and P0700
- DF Video!
- New to Dodge
- Poor mpg's & 3 codes!! Help!
- Impact wrench
- 2001 Intrepid Starting Problem. Can it be a switch in the steering column
- Fan settings aren't working anymore
