Sticky injector?
Sticky injector?
I bought this truck two weeks ago, not knowing the amount of problems it really had. My main problem right now is that when you use the throttle you either have to open it up all the way or you can barely touch the it. If you are in the middle of the pedal the truck will rev up and die off. At first I thought it was the map sensor. I replaced that. Now I am looking at the O2 sensor and a Sticky injector. Does anyone have any other suggestions as to what the problem could be.
Welcome to DF. Please take a few minutes and read the section descriptions so you post in the correct area. This section is for reporting issues with the Dodge Forum internet site, not vehicle specific sections. From the main form page, scroll until you find the section appropriate for your vehicle and post your question there. It also helps if you state what vehicle you are referring to. Make, model, engine size, mileage, transmission.
