DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Cars > Dodge Intrepid
Dodge Intrepid The sporty car that recently left the Dodge lineup, the Dodge Intrepid. With it's smooth look and comfortable ride, the Dodge Intrepid can still command attention.
Thread Tools Search this Thread
Old 03-25-2009, 05:32 PM
mistertudball mistertudball is offline
Default Power Steering Noise When Cold
I'm guessing Dodge put the same power steering system into many more cars than my 98 Intrepid (3.2 engine) so I wonder if anyone else has from the northern climes has experienced a nasty grinding/groaning sound for the first 15 seconds or so after starting up their cars when it's freezing or below. For some reason 32 degrees seems to be the benchmark. My mechanic said Intrepids were recalled for this, they replaced the fluid with something else, and it was "better" but not remotely gone.
The noise is loud enough to make people many car lengths away in a parking lot look at you like you just started up a chipper/shredder! But as I said it goes away in 10-20 seconds and does not come back until it all cools down again.
The car has 127,000 miles so I presume it needs a new pump, but does power steering fluid freeze?
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 03-25-2009, 08:52 PM
dhvaughan's Avatar
dhvaughan dhvaughan is offline
Vehicle: 01 1500 4wd
consider this. the ps on my old chevy truck started groaning and feeling tight. i bought a turkey baster at walmart and a quart of ps fluid at autozone. can't remember what kind, maybe valvoline.
using the turkey baster i sucked all the fluid i could from the reservoir and refilled it. the oil was really nasty looking. then started it up and drove it around the block. noise was gone. shut it off and did it again. drove it around and then check how it looked with the baster. not bad (and i didn't have enough oil for a 3rd time), so i left it at that.
i think the groaning noise is oil bypassing the seals. oil does not freeze, but cold weather makes oil thicker and rubber stiffer.
__________________
01 1500 Reg Cab 4wd 5.2 auto 3.55 285/75/16 nasta step bar tow hook sc3815 180 3923 trans cooler/filter posi-lok powertrax noslip timbren brite-box pioneer head rockford amp/speaker cobra cb firestick hughes plenum water pump timing chain oil pump rear seal front bearings brakes shocks cracked dash towing composting boat.
Tags
03, box, charger, cold, dodge, durango, freezes, intrepid, magnum, noise, noises, noisy, oil, power, steering, type
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
Vendor Directory
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
