Dodge Intrepid The sporty car that recently left the Dodge lineup, the Dodge Intrepid. With it's smooth look and comfortable ride, the Dodge Intrepid can still command attention.
Location of Cam Shaft Sensor
Old 03-13-2010, 12:22 PM
LVBlkScorpio's Avatar
LVBlkScorpio
LVBlkScorpio is offline
Default Location of Cam Shaft Sensor
I am looking for the location of the Cam Shaft sensor on an 04 Dodge Intrepid SXT. The engine light shows codes for both banks for the cam shaft sensor and the car stalls when driving I thought that I should start with replacing this sensor first before I moved on to the O2
Old 03-19-2010, 01:05 AM
lennemann23's Avatar
lennemann23
lennemann23 is offline
You can go to autozone.com and select your car type and engine liter and then go to sensor location and it will tell you everything you need to know.
Old 04-10-2010, 03:13 AM
j3ck37's Avatar
j3ck37
j3ck37 is offline
in the front of the motor near the camshaft pulley there should be only 1 bolt holding it on.
Old 04-10-2010, 07:11 PM
Tizzy1's Avatar
Tizzy1
Tizzy1 is offline
REMOVAL - 2.7L
The camshaft position sensor is mounted in the front of the head.
  1. Disconnect electrical connector from sensor.
  2. Remove camshaft position sensor screw.
  3. Without pulling on the connector, pull the sensor out of the chain case cover.
REMOVAL - 3.5L
The camshaft position sensor is installed in the timing belt housing cover above the left camshaft sprocket.
  1. Disconnect the negative battery cable.
  2. Loosen the upper intake plenum, refer to the Intake System section.
  3. Disconnect electrical connector from sensor.
  4. Remove camshaft position sensor screw.
  5. Pull sensor up out of the timing belt housing cover.
Quick Reply: Location of Cam Shaft Sensor
