journey fuel guage issue
Good evening Folks, i have a 2011 journey crew, and from day 1 have had isues with my fuel gage not completly filling, when i would fill it it would only get to 3/4 full and after that it would only fill to the 7/8 mark. so i let it get all the way empty and when i filled it it only would take 60L of the 80. When i took it to the dealer they said they would change the fuel sending unit. That worked for about a week and now its doing it again. they looked at it a second time and dont seem to know whats going on. Anyone have any ideas?
thanks
thanks
I would ask them to drop the gas tank and move the sending unit by hand, and see if the gauge goes to top. If it does, you probably need a gas tank. If not, problem might be the gauge or a bad new fuel sending unit.
I've seen this b4 on a 2011 journey, but the fuel sending units fixed the problem tho.
The following users liked this post:
Lily daPink (06-20-2023)
When you say have the dealer calibrate the gauge is that something they can do with a scan tool.
Thanks Jerry
Same Problem
I bought a 2012 Journey with 3.6 L engine. Gas gauge has the same problem with only showing 7/8 when I fill. Ran it down to 58 miles distance to empty and took less than 15 gallons to fill it. Took to dealer today (10-8-2014) and they told me that there is no software update for the problem. They have no idea on how to resolve the problem. I guess I will try running it below empty and see what happens.
Trending Topics
The bulletin is for "Fuel gauge will not read full after filling up the fuel tank". The repair is to replace the fuel pump module.
MODELS:
2011 - 2012 (JC) Journey
NOTE: This bulletin applies to vehicles equipped with 3.6L, or 2.0L Turbo Diesel engine (sales code ERB or EBT) equipped with a 20.5 Gallon Fuel Tank (sales code NFP) built before May 30, 2012 (MDH 0530XX) or 2.4L engine (sales code ED3) equipped with a 20.5 Gallon Fuel Tank (sales code NFP) or export fuel tank (sales code XDC) built before May 30, 2012 (MDH 0530XX).
NOTE: This bulletin DOES NOT apply to vehicles equipped with All Wheel drive (AWD).
SYMPTOM/CONDITION:
After filling up the fuel tank, the customer may notice that their fuel gauge does not read full. On further inspection the tech will NOT find any Diagnostic Trouble Codes (DTC) for this condition.
Replacement of the Fuel pump module will repair this concern.
DIAGNOSIS:
Using a Scan Tool (wiTECH) with the appropriate Diagnostic Procedures available in TechCONNECT. This condition will not set any DTC's, however if any of the DTC's listed below are present record them on the repair order and repair them first before proceeding further with this bulletin.
· P0460-11 - Fuel Level Sensor 1 - Circuit Short To Ground
· P0460-15 - Fuel level sensor 1 - circuit short to battery or open
· P2065-11 - Fuel level sensor 2 - circuit short to ground
· P2065-15 - Fuel level sensor 2 - circuit short to battery or open
· P0461 - Fuel level sensor 1 performance
· P0462 - Fuel level sensor 1 circuit low
· P0463 - Fuel level sensor 1 circuit high
· U110C - Lost fuel level message
· U1411 - Implausible fuel volume signal received
NOTE: If the customer has any other fuel gauge symptoms other than the one listed above, this bulletin does not apply and normal diagnostic needs to be performed.
If the customer describes the symptom, perform the Repair Procedure.
