Aftermarket radio - or replace with OEM?
Hi all!
I've just become the proud owner of a 2014 Journey base model; an older relative just bought it and then took ill, so I got the vehicle for extremely cheap.
As the base model, it doesn't come with Bluetooth or anything fun like that, and I'd like to replace the existing radio.
A number of aftermarket radios are out there, but I'm thinking that an OEM unit might be the way to go given all of the integration with the climate controls and things like that. I don't know that I want to spent a bazillion dollars for what ultimately would amount to Bluetooth and DVD, though.
My question for the forum: Has anyone replaced a Journey radio unit with either an upgraded OEM unit or an aftermarket? What was the experience after the fact? I'm guessing that aftermarket would necessarily lose all of the in-vehicle integration - right? Can you actually buy an OEM upgraded unit, and do they actually work? I certainly understand that you're not going to get the reverse camera and (probably) GPS functionality since neither of those would have their respective infrastructures installed...
Any advice would be appreciated. Thanks a ton!
Thanks very much for the reply, jkeaton!
Makes sense. I'm mostly wondering about stuff like Bluetooth, etc.
So, for example:
If I find an OEM radio off a scrapped vehicle (recovery from a wreck, etc), there are obvious things that won't work - rear camera (since there isn't one), etc. Will the rest of the stuff - Bluetooth, the integration with the HVAC system, etc - still function, or is even that a loss?
So, for example:
I have a 2009 journey. I picked up a pioneer fh-x700bt. going to be installed that today. I purchased an OEM integration kit as well so I can use my steering wheel controls with the aftermarket Stereo. I'll let you know how it goes.
But I do know that its ALOT cheaper to buy after market than OEM. This whole package cost me $300 shipped to me. OEM last time I checked used was $700+ on kijiji.
installed the Pioneer FH-X700BT in my 09 Dodge Journey today. Took just about 2 hours total. saved my self $600 on install fee at a shop.
Everything was pretty much straight forward direct plug or solder matching colour wires. Everything tie wrapped neatly and put behind stereo. Front AC panel sits ON flush. only thing is the aftermarket Stereo bracket doesnt have the clips space for the panel clips to click into it, but you cant even tell.
The "worst" part was removing the left side panels by the wind shield and Door to pass the Microphone cable for the Hands free. I clipped it above the rear view mirror. cable is hidden. Audio quality is awesome for both music and phone calls. everything can be done from the front panel of the Stereo receiver, including Bluetooth Audio play.
Trending Topics
Bluetooth Unit for Dodge: http://cruxinterfacing.com/products/...35C/index.html
Available here: http://www.icarkits.com/products/BEECR35C
