Dodge Journey Dodge Journey forum for discussion on the popular Dodge Crossover and CUV.
2012 Journey SXT ABS/Traction control light is on.
Old 07-04-2015, 02:30 AM
59skippy's Avatar
59skippy
59skippy is offline
Default 2012 Journey SXT ABS/Traction control light is on.
I have had intermittent (more on than off) ABS/Traction Control light on in a '12 Journey SXT FWD.
I replaced the very worn rear rotor and brake pads. Now the light is always on.
How do I pinpoint the problem? There was no wiring into or around the rear hub or on the caliper.
Old 07-04-2015, 12:23 PM
bigtsr's Avatar
bigtsr
bigtsr is offline
Does the wheel spin freely rotating by hand?
Possibly emergency hanging up.
Did you rotate the pad actuators when you installed the new pads?
Old 07-05-2015, 01:02 AM
59skippy's Avatar
59skippy
59skippy is offline
The rear wheels spin freely. I did turn the actuators fully to be able to install the new rotor and brake pads.
I did not see any electronics going into the hub/axle assembly on the rear axle of my FWD Journey.
Old 07-05-2015, 07:04 AM
bigtsr's Avatar
bigtsr
bigtsr is offline
I looked at the parts manual and I don't see any
sensors on the rear either so I would assume that
the indicator is being generated by one of the front
brake assys that do have sensors.
Old 07-05-2015, 05:40 PM
59skippy's Avatar
59skippy
59skippy is offline
Thank you for the information. Muchly appreciated. Now to start on the front caliper/rotor/sensor evaluation
Old 07-06-2015, 02:04 PM
DodgeCares's Avatar
DodgeCares
DodgeCares is offline
Are there any trouble codes present, 59skippy?
Quick Reply: 2012 Journey SXT ABS/Traction control light is on.
