the 722.6 has two speed sensors. here is an accurate quote from MB forum:
http://www.benzworld.org/forums/w210...ml#post3647185
note, this thread was discussing limp mode due to speed sensor failure.
"722.6 Conductor Plate
The conductor plate is on top of the valve body and houses six solenoids and two sensors, a few other things. Common failures are the two speed sensors, which cannot be replaced separately so the entire conductor plate has to be replaced. This part has also received multiple updates so make sure you get the latest part.
When the speed sensors fail, the ETC does not know the input/output shaft speeds so it does not (know) what gear the transmission is in. If the failure is intermittent, then the ETC will go into “Mechanical-hydraulic” limp home mode. If the problem is more severe, then the ETC triggers the “electric” Limp Home mode.
Typical symptoms of speed sensor failure are erratic shifting or no shifting at all. The best diagnosis is to read the codes in the ETC using special scanners. If there are 012 (108) or 013 (109) codes, then the problems are likely the speed sensors.
If no special scanners are available, then at east read the codes using a generic OBD II scanner. Chances are the Check Engine Light (CEL) is on. If the codes are P0715 or P0720, again, the problems are likely due to the speed sensors. I said likely because the generic P0715 is mapped to several Mercedes codes. However, based on what has been seen, P0715 is a pretty reliable indicator of speed sensor failure.
Yours truly
replaced the conductor plate on a 1997 E320 and you can find the instructions
here.
P.S. "G-AMG" posted a combined
Photo DIY- 722.6 Conductor Plate and Regulator Valve Spring R/R DIY."
