2005 dodge magnum rt (69,000 miles)
Hey everyone, new member long time reader!!! Getting a clunking noise on the front driver side only on big bumps or mostly when there are alot of little bumps in a row. I had it jacked up found nothing (but i'm no expert by any means) took it to a expert and he found nothing out of the ordinary. Looking for suggestions (my thought is strunt but I can bounce the car up and down with no noise)
im back!!! the noise turned out to be the front sway bay bushings> rpl the front strunts still had the noise> disconnected one side of the sway bar the noise went away. rpl the bushing noise is gone > just hit another bump in the road , driver side power lock not working. any way i can get a eletrical diagram i dont think it anything serious but that schamatic would help thanks and any kind of feed back helps
