Lights Pulsing - DodgeForum.com
Lights Pulsing
Old 08-16-2012, 10:50 PM
Bernie530
Bernie530 is offline
Default Lights Pulsing
Hi everybody. Brand new to the forum, and brand new to Dodge Magnum ownership. I just purchased a 2005 Magnum SL with the 2.7 L engine. Very basic car.
I have driven it about 1500 miles, and tonight the lights started pulsing. While driving, the headlights were pulsing like there was a high load going on and off the electrical system.
No codes, so I pulled the battery to reset things. The problem came back in five minutes of driving.
Any suggestions?
Old 08-16-2012, 11:05 PM
steak59
steak59 is offline
Check if ur tail light pulse as well. Head light switch are fairly common failure.
Old 08-17-2012, 10:01 AM
Bernie530
Quote:
All of the lights are pulsing (headlights, tail lights, dash, everything).
Thanks
Old 08-17-2012, 11:08 PM
steak59
steak59 is offline
Try this, disconnect the head light switch. now your light should stay permently ON.
tools you need will probably be a philip screw driver and flat head screw driver.
Some Charger would have a T20 torx tho.
you remove the knee bolster panel so you can push the switch out from the inside.
1 screw at the bottom (6), one screw on the left side(2). the top is clip on.
Old 08-18-2012, 03:07 AM
Bernie530
Its not a headlight problem, it is an electrical system problem. If it were only the headlights, the tail lights and other items would not be affected as well.
Old 08-18-2012, 11:41 AM
steak59
steak59 is offline
When you flip ON the head light switch, the tail light and dash light comes ON too, right? ur problem is only lighting, right? the head light switch controls ALL lighting in ur car.
or the whole car would choke, sputter, and die out?
Old 08-20-2012, 12:48 PM
Bernie530
I will try it next week (car is getting some paint work now), but I am super doubtful. It is a Can Bus system, so the power for the lights never goes to that switch. That switch is digital (read, on or off). It just tells the computer to turn on the lights of turn off the lights. I don't see how it would dim or pulse the lights.
Old 09-29-2012, 05:16 AM
waterboi74
waterboi74 is offline
Quote:
Posted from Dodgeforum.com App for Android
Related Topics
Thread
Forum
Replies
Last Post
dirtyjay
4
03-22-2016 06:17 AM
herche54
2nd Gen Ram Tech
13
07-17-2015 05:38 PM
losdickson
Dodge Caravan
0
07-15-2015 05:13 PM
kenb1023
2nd Gen Ram Tech
2
07-06-2015 01:44 PM
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
