Jetchip performance chip
This months Hot Rod has a small article about the Jetchip performance PCM chip for the Magnum on page 128.
Says there is stage 1 and stage 2 chips and states 12 HP boost upon dyno but does not say which chip they tested.
Anyone have one and is it worth the $309.95 ST-1 / $319.96 ST-2 ??
RE: Jetchip performance chip
my car never even left the garage after i put my jet chip in. the engine light was on and i had two codes: P 0499, P 0037.
i took the chip back out, cleared the codes, and it runs perfect again. be carefull, there seems to be a lot of bad chips out there. roll the dice and try it. you may get lucky.
Found a new Stage II Jetchip on ebay for $145 and bought it to try.
Will let you all know what happens. Comes with a factory warranty so even a fool can get reunited with his money.
65standard: Did you return your Jetchip for a refund? If I do get a code, can I clear it myself or is that a dealer only procedure?
Trending Topics
ORIGINAL: Microdax
i will try to return it or get a refund, but i bought it off ebay like you. i didn't get any replies back to my e-mails from the seller. yes, you can clear the codes and get the light to turn off, but they're still hidden in the computers memory. only the dealer can completely clear the codes.
