2007 dodge magnum r/t 5.7 hemi
05-17-2014, 11:24 PM
on
My 07 dodge magnum won't start. All the lights, dash, and radio turn on but no start battery it good had it tested doesn't crank or click, it's completely quiet there's a click in the fuse box in next to the battery in the trunk but that's all. Any help on where else to check or how to fix it? Thanks
05-25-2014, 05:37 PM
on
Try and give the starter a Gentle hit with a hammer or a wrinch, sometimes the magnet can get stuck in there, and after a hit or 2 it can move again. If that doesnt work, try and find a used one that u can buy or borrow to swap out and see if that helps.
05-26-2014, 01:54 PM
on
Thanks for the response it was the ignition safety switch I swapped it and it fixed the issue
09-26-2014, 07:57 PM
on
Check your fob battery and then disconnect the battery for 30 seconds or so. If your fob battery goes dead you get about 5 start attempts then the security kicks in and locks you out.
