2008 Magnum - shifter moves back and forth
Hi all,
I have a 2008 Magnum 2.7L, bought in 2012, now with 145,000kms (about 90,000 miles).
Last week, with my foot on the brake as usual, I was leaving for work and I shifted out of Park to go into Drive. The shifter moved very freely and went past D into 3. Odd, I thought. Then I realized that the shifter was simply moving back and forth, it wasn't taking the car out of Park. The shifter was not hanging up anywhere, and the trans was holding Park (ie. the car stays put).
I have taken as much of the console apart as I can, and have done many Internet searches, but the main prob with the Magnum shifters is that the little pink thingy breaks and prevents the shifter from coming out of Part. That's not the problem - my shifter moves freely, it just isn't connected to anything any more.
The little pink part seems to be fine, and the rod (that disappears into the front of the console) moves back and forth just fine.
Any suggestions?
Any suggestions?
Hi all,
Any suggestions?
Any suggestions?
I'm sorry to hear about your shifting issue. Had you been experiencing any abnormalities when shifting previously?
Have you had an opportunity to speak with your servicing dealer?
My shifter
HI DodgeCACares,
I did not experience any abnormalities when shifting previously. The movement from P through to D has always been smooth with no friction or hangups. I have not yet spoken to my local Dodge dealer, as I am on a limited budget and I am trying to diagnose as much as I can, before I take it in for the repair (I do not intend to do any repair myself).
HI DodgeCACares,
In some cases, what you've described can be associated with the gearshift cable. A formal diagnosis would be beneficial to efficiently determine the root cause. Your ability to demonstrate the issue will certainly help the process.
