06 magnum se v6 2.7 want to do a v8 swap
Not true. Anything is possible with enough time and money. Op what is your budget for this swap? Doing a V8 swap will require a lot more than just the engine and depending on where you get the parts and who's doing the work, can cost you $5,000 to $10,000 or more. If you do a 5.7 swap you would need EVERYTHING from the donor car, all the wire harness, ECM, TCM, tranny, probably gauge cluster and shifter, etc. etc. If having a V8 is what you want, you should consider selling your car and buying a Hemi R/T or SRT
^ X2. Less problems if something isn't installed correctly or a part (Engine tranny etc) is bad or has a good amount of wear, going to cost you a lot of money. I would say 10k plus. Also no warranty on anything. Buy a used r/t and depending on dealership and mileage, they might give you a small warranty with a possibility of an extended warranty. With a swap like that you basically open the hood and replace everything...and tranny, and driveshaft, and you have to see if the axles need changed out because the v8 ones might be bigger...
Overall you can get an r/t for the same price or less than a swap and it will look like an r/t with the higher level wheels, brakes, emblems, etc
Or upgrade yours for less than $5k...exhaust, custom tune, intake...or for more money, high performance internals. Stock is 190hp. With intake, tune, and exhaust general rule of thumb is about a 15 percent increase. So based on that you could add about a 29 hp increase. I had a custom tune and intake on my 08 V6 f150 and the tune feels like more than it gives a lot of times because the numbers are the peaks and tunes strengthen the whole power band. High performance internals. ...for 10k you could supercharge it or do a camshaft or whatever. A high performance camshaft can give you a lot more power but other internals may be required too. Custom tune is required with any aggressive upgrade....and may be required for mild ones. Intake and exhaust you don't need to. There are also ways to make your stock intake flow better and flow more air for less than $20 plus the higher flow filter (usually about $60 but is usually a clean and reuse filter for life). Dry filters you can vacuum off the dirt and reinstall, wet AKA oiled filters are a little more involved in cleaning but can have a less restricted flow. Oiled filters also have a risk of sucking in the oil thru the filter if too much is applied which can get on sensors in your intake and make them read wrong. They can be cleaned still tho. I have had oiled filters(k&n) for over 10 years and never had a problem because of them. Also had them in 5 vehicles over that time.
