pcm,ecm computer location
Old 11-10-2005, 12:48 AM
Magnum 2005's Avatar
Magnum 2005
Magnum 2005 is offline
Default pcm,ecm computer location
where is the computer for the Dodge Magnum 2005 located ???
Old 11-12-2005, 12:57 AM
EMB's Avatar
EMB
EMB is offline
Default RE: pcm,ecm computer location
ECM is under the passenger side front corner engine compartment, under the bracket that is over the fresh air intake...just beside the hood hinge.
Ed
Old 11-12-2005, 08:26 PM
Magnum 2005
Thanks found it not sure how to get to it if I decide to put in a chip
Old 11-13-2005, 05:55 AM
Husker's Avatar
Husker
Husker is offline
It's pretty easy. I put my Jet Stage II in my mag in about 15 minutes. Just remember to remove the dustcover from the plug-in and it all fits good.
Old 11-13-2005, 10:23 AM
Magnum 2005
To use the JetII you have other mods correct,,did you do the chip after using the other mods for a while or did you do them all at once???
Old 11-13-2005, 01:55 PM
65standard's Avatar
65standard
65standard is offline
just pull the 2 push-pin on the vented cover to get to the 13mm bolt holding the computer down.
[IMG]local://upfiles/13006/E0E86F21385F4C978588509D396AE902.jpg[/IMG]
Quick Reply: pcm,ecm computer location
