DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Cars > Dodge Neon
Thread Tools Search this Thread
Old 01-10-2005, 04:15 AM
GroundControl GroundControl is offline
Send a message via AIM to GroundControl
Default RE: srt-4 turbo
where did u get that 16 g from. looks liek its for a sohc right? why dont they make a turbo that will hook up to the stock manifold?
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
__________________
....The Neon Is Sold....
(The car is now Fu**ed up!)
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 01-10-2005, 04:30 AM
Cr@zy Squ33 Cr@zy Squ33 is offline
Send a message via AIM to Cr@zy Squ33 Send a message via Yahoo to Cr@zy Squ33
That's a Chill Factory SOHC manifold.
They don't make them to fit stock manifolds because the stock manifold isn't designed to support a turbo.
A turbo is not an off the shelf random part. Its a performance part and needs performance compnents to even work.
Old 01-10-2005, 08:35 AM
71RoadRunner's Avatar
71RoadRunner 71RoadRunner is offline
Send a message via AIM to 71RoadRunner
OK, here it goes. The SRT-4's turbocharger and exhaust manifold is one single piece and it is not a T3/T4 turbo, it is a smaller quicker spooling turbo. There is no way to seperate the two since they are one single piece.
You will need to upgrade several other parts to properly run a turbocharger, fuel pump, injectors, boost controller, etc. Your biggest concern will be the increase in compression, you can only run a few pounds of boost on a stock 2.0L, running at the SRT-4's boost levels (14-15psi) will blow the motor. You would be far better off buying a turbo kit that is built for your 2.0L, then trying to retrofit an SRT-4 turbo on it.
The Stage 2 upgrade doesn't replace the turbo or the intercooler, so how is it that he can sell them just because he got the Stage 2 upgrade?
__________________
71 Plymouth Roadrunner 440 Auto. Modified
04 Dodge SRT-4 2.4L DOHC Turbo Intercooled 5-spd. Modified
Old 01-10-2005, 08:54 AM
Noizemaker Noizemaker is offline
71RR has it right. The cold side of the turbo is one piece, but the hot side is cast into the manifold... and I had to do a crapload of stuff in conjunction with it to make it run, don't expect to bolt on and go.... I had to:
bolt up mani/turbo
run new coolant/oil lines for the turbo *SRT doesn't fit*
custom-make exhaust.
custon-make IC piping to my sidemount IC
bigger injectors
bigger fuel pump
fuel pressure regulator
buid Overboost eliminator
run new fuel lines from rail to regulator and back to tank
plumb fuel return into tank
I know there's more, i'm just too tired to remember.
__________________
-Matt
Old 01-10-2005, 03:03 PM
dame thats alot of work. Im not sure why he was getting rid of the intercooler and everything unless he was getting a bigger one. Dont ask me i dont no the guy, all i new was he wanted 450 for eveyhting and an extra 150 for the intercooler. Its probley gone now anyway but if was easy to do id find on quick anyhow. So the only good way out is the chill factory. thats like 3,000. Thats a big DENT in the wallet.
__________________
Old 01-10-2005, 06:07 PM
Quote:
ORIGINAL: 71RoadRunner
Tahnks 71RR, I had no idea that the SRT was a cast piece. I was just trying to help him out. Didn't actually know how the SRT turbo was setup.
I was going off of my experience with my setup and I've had to buy a bunch of parts myself. Fuel line, regulators, boost controller, fuel rail, injectors...all of it.
Old 01-10-2005, 07:09 PM
LowSlowNeon LowSlowNeon is offline
Vehicle: 2004 Dodge Neon
Send a message via AIM to LowSlowNeon
Yep, I'm right there with you nick. It would be too much work for me to try and use the SRT turbo setup, I however probably will use some of its components.
__________________
04 MTX
Canon 400D|17-40mm f/4L USM
Old 01-10-2005, 07:14 PM
I think its easier to build your own kit anyway. More fun that way.
GroundControl, you should look into piecing together your own kit. It's a lot of fun and you learn quite a bit more when researching things instead of buying a kit.
Old 01-10-2005, 07:19 PM
So true.
__________________
04 MTX
Old 01-10-2005, 07:20 PM
I think anyone thinking about going turbo should read Maximum Boost by Corky Bell before they do anything. Its a very good book and you will learn alot.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
