DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Cars > Dodge Neon
Thread Tools Search this Thread
  #31
Old 07-02-2005, 02:04 AM
01NeonR/T 01NeonR/T is offline
Default RE: Why you should run platinum plugs in the neon!
Oh this is perfect. I was just about to go to the parts store to find some new plugs. I changed from the original owner's +4's to +2 from Bosch and since then the car has had some problems keeping a steady idle. Sometimes it jumps like the timing is off, other times it nearly dies, and still other times the needle stays steady but the motor feels really rough. Vibrates quite a bit. I looked under the hood and think I also need new motor mounts. I think I need to rebuild the motor. Eats a bit of oil. Once underway it's okay. Well I do drive the snot out of the car. It IS my daily driver after all. Since it still runs relatively well I'm surprised. Lasted lot longer than that old Integra I used to have :-P So what would you all suggest I should change to? BTW I found later that #3 cylinder plug had actually BACKED out a bit.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
__________________
Ricer methodology:
So my Neon has leather therefore it adds 5 hp.
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
  #32
Old 07-11-2005, 02:55 AM
I just changed over to NGK V"Power" Copper core plugs. $1.79 per plug. All I can say is.. WOW.
__________________
Ricer methodology:
  #33
Old 08-16-2005, 08:23 PM
casper casper is offline
Send a message via AIM to casper
I just pulled the plugs in my car and the +4's look brand new, just for fun, I put some NKGs in and it runs worse, I have better response with the +4's.
__________________
1998 Neon- Iceman intake, Pacesetter exhaust, Megan racing short shifter, Kirk Racing header, AFX solid race front mount, AFX solid bobble strut
Come play hood wars
http://www.hoodwar.com/register.php?REF=329
  #34
Old 08-24-2005, 04:48 AM
ewetho ewetho is offline
Vehicle: 2004 Neon SE
Consider thyself lucky as they mentioned before that even Bosch admits they are truly not compatable with DIS ignition. So best bet is either a Double Platinum plug (Developed because of DIS problems) or copper. Iridium should be just fine as well.
__________________
2004 Neon SE -- [size=1]K&N CAI, R/T Muffler, Booger Bushings, Prothane Suspension & Race MM Inserts, Vitor's TM Inserts, Progress 22MM Rear Sway Bar w/ Energy Suspension 2 3/8" End Links, Vogtland Springs, KYB GR2 Struts, Vibrant Type V Strut Bars[/size
  #35
Old 08-31-2005, 02:47 AM
neonnot neonnot is offline
Default RE: Why you shouldnt run platinum plugs in the neon!
I've been having poor performance from a neon, so I started reading some of the info in the forum, and it matched the problems we were having on a 2000 model. So, we went back to the standard NGK plug and changed the wires since the car has 93k on it, and our problems went away.....the platinum plugs had 38k on them, gas milage was down to 20 mpg hi-way, and under hard accel. from a stop it was life threating to pull out into traffic. During the r&r of the plugs we referanced a Chiltons for various info and discovered that neons of different year models use different plugs......look on the sticker under the hood to be sure what your neon was using when it was built.
  #36
Old 12-06-2005, 03:20 AM
tonedef1 tonedef1 is offline
When i brought my neon 95 SOHC I wondered Why it was running like @@@@ it had a very poor idle and was rough(it also had no power). So I went through it and changed the wires and pulled the plugs they sere boch platinium plugs. It as a little hadr to tell they were even spark plugs since they were burned badly and had no electrode. I changed them and to denso and the car runs like a champ. I think the coil just doesnt like platinum plugs and they would work with an msd coil. i never liked platnium plugs anyway copper conducts better
__________________
I did love neons at one time........ untill i bought one
  #37
Old 12-12-2005, 06:35 AM
joejunior253 joejunior253 is offline
hey i have been wondering why my neon would sputter or hesitate at a red light and i noticed that in one of your web pages listed the guy had said it was his spark plugs. so i'll try some new ngks and see if they work. thanks for the info
__________________
2001 dodge neon es atx
dual magnaflow exhaust, ngk plugs and msd wires.
  #38
Old 01-11-2006, 09:26 PM
DodgePerformance DodgePerformance is offline
I use the Bosch Platinums, no problems, but cars seems to high rev when its cold. Plus has this sound like a turbo, when its not. I don't know why it makes that sound, sounds crappy. When car warms up it goes away. Don't know if any others have this problem.
__________________
98 Neon 3spd Auto
Custom SRI intake, K/N Filter
Optima YellowTop
120A ALT
Indigo Gauges
Stinger Voltmeter
Stereo
Sony CDX-M630
XM SKYFI2
Boston FS60 6.5 Comps in Front, Boston FX93 6x9 in Rear
PA A2400db
2 12" PA Fubr's
  #39
Old 01-13-2006, 02:28 AM
Sounds bad well, then it is time to try proper selection of plugs. Go to either basic plugs, Champion or NGK. Then there are better plugs such as Double Platinum (RUN GREAT) or Iridium. See what happens. Make sure the gap is right!!!
__________________
  #40
Old 01-16-2006, 05:28 AM
Jporter2147 Jporter2147 is offline
I just bought my neon about 4 months ago. (2005 SXT Auto Trans) I am new to this whole car thing and my brother in-law told me to come here with questions. (Brother in-law is a mercedes tech. He doesn't like dodge.) I was wondering about the whole Nology thing. Why are the not good? Oh and thanks for all the info so far. I have already learned alot of what to look for when buying parts. Thanks everyone.
__________________
J.P. 2005 SXT
A work in progress.
Tags
04, ac, backing, delco, dodge, double, gapping, mufflers, neon, out, platinum, plugs, professional, spark, vibrant, vpower, vs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
