1995 neon water pump replacement how hard to do ? - DodgeForum.com
Old 02-25-2012, 02:30 PM
moparsrule60
moparsrule60 is offline
Default 1995 neon water pump replacement how hard to do ?
Need to replace a leaking water pump on my 1995 Neon, understand most of the steps to do this. If not disturbing the engine and marking the pulleys and replacing them the exact way they were originally and putting everything back together what kind of timing issues will I have if any ? I replaced a water pump once on a Ford Escort and all I did was mark the pulleys and dampener and the block to make sure the they were in the original place when I started. Then all I had to was put everything back in place and the car ran fine. Also heard after replacing the water pump on my Neon would have to hook it up to something so the engine would have to relearn its codes is this true. Just want to know much of a pain this whole process this can be. Thanks for any advice. Mopars Rule
Related Topics
Thread
Forum
Replies
Last Post
Khris1994
2nd Gen Ram Tech
121
10-24-2015 03:47 PM
JeeperDon
1st Gen Durango
15
08-20-2015 08:32 PM
rampulstilskin
2nd Gen Ram Tech
14
08-19-2015 01:40 PM
Dalbert
Dodge Ram Van
8
07-08-2015 11:33 AM
rickluc
3rd Gen Dakota
1
07-08-2015 10:26 AM
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
