DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Cars > Dodge Neon
Thread Tools Search this Thread
  #31
Old 02-11-2008, 04:57 PM
inthewerks inthewerks is offline
Default RE: Common Dodge Neon Repairs and Problems
hey everyone. heres my problem. 05 sxt auto tranny. in neutral, i cant rev the rpm's up. it stutters real bad at first then picks up like normal. also, above 2500 rpm's in drive, it starts to miss ever so slightly i can hardly feel it but i know its there. replaced plugs, wires and went msd for replacement coil. fuel system checks ok. any thoughts? tps maybe?
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
  #32
Old 03-21-2008, 05:50 PM
AlyssaN AlyssaN is offline
hey i have a 2001 neon and about a year ago my cable broke and i was stuck inbetween 2 and 3 i had it fixed and had them put a thicker cable and its been running great since then it will cost you about 300 bucks but i havent had any shifting problems since
  #33
Old 04-17-2008, 04:02 PM
Redsoxneon Redsoxneon is offline
My 2004 dodge neon started sputtering and bucking,changed the plugs and wires, and added water remover, its stopped for a littlebit then it started up again any suggestions what i gotta do
__________________
Neon
  #34
Old 06-04-2008, 11:32 PM
LIBRA_099 LIBRA_099 is offline
Hey i have a 2002 Neon Se and when i turn on the A/c it blows warm air and when i looked under the hood at the lines the sending line was cold but the condensor was warm and not even the slightest bit cold. And the kicker was i just had the A/c filled 3 weeks ago. Any suggestions?
__________________
AAG
  #35
Old 06-25-2008, 06:06 AM
N30N N30N is offline
Vehicle: Invisible Dodge Boat Mobile.
Send a message via AIM to N30N Send a message via Yahoo to N30N
everyone has common problems
1.swaying
2.control arms
3.studdering
4.leaks in the trunk/back seat
its all the same[sm=gobble.gif]
__________________
  #36
Old 08-03-2008, 06:13 PM
RPGGUY07 RPGGUY07 is offline
New Member
hey guys i have a problem with my 04 neon se. the thing is since i bought the car used its previous owner was in a wreck so wen they fixed the car from the front whoever put the front bumper back on didnt do a good job i just noticed this there is a gap on my headlights were the bumper is suppose to go ok well wen i installed my intake i did not notice the gaping hole so wen i was washing my car i notice i could see my intake filter and how it was soaking wet!!! i was thinking of buying a shield or cover sumthin that would protect it from any water coming in through the hole in the body since i figured it would cost way more to actually take it to a body shop so they could actually fix it. so any ideas on how i can seal the hole and cover my intake so water wont get in?? does anyone think a heat shield would do anygood for that?
  #37
Old 08-13-2008, 11:37 PM
sevans sevans is offline
Junior Member
Default Weird Noise from 98' Neon
My 98' Dodge Neon is making a continuous scraping noise when I'm in drive or reversing. The noise is originating from the right front tire area. But when I brake the noise stops. I don't know what the noise could be. I'm also unable to get this repaired for at least six weeks, is it safe to drive?
-A Girl.
  #38
Old 09-23-2008, 03:24 PM
ac1988 ac1988 is offline
Question
So, I took it in for diagnostics... but I guess I’m bringing it home to do the tune-up, it’s got almost 80k and apparently needs new spark plugs, a new air filter, and fuel injector cleaner... any suggestions? Should it run fine and get better mileage after all that is fixed and not start misfiring, and the engine light will go off?
  #39
Old 10-13-2008, 01:56 PM
jezzika jezzika is offline
I have a 2002 Neon (automatic) and I have been having some
weird sporadic problems. I can't get them to reproduce but
occasionally.
Started out, I would start up the car and take off.... and as
I want to push down the gas to get up to a speed, the car
doesn't go anywhere.... you just kinda hear the engine rev and
then all of a sudden it'll jerk and start moving. Like a
break is stuck or something?
NEXT, I was pulling out of my parking spot one day, put the
car in drive to pull out and the car started to go in reverse.
It wasn't just an idling roll backwards, it went completely
backwards!!
On a separate incident, the opposite happened - I put the car
in reverse and it went forward!
So to sum it up - it kinda stalls and revs at me, it goes
forward in reverse and reverse in drive. For now.
It's really freaking me out and I don't know what to check for
and I don't know if it's worth spending the money I know it's
probably going to cost me to fix it?
Any help would be greatly appreciated!!!
  #40
Old 01-27-2009, 07:35 PM
Mickii Mickii is offline
Exclamation what the hell
i have had my 96 neon for about 8 months......since the i have change both my belts. my car leaks every oil it is capable of leaking. my sevice engine light comes on & it rattles. there is a severe squeaking noise coming from it....OMG whats wrong with my car.. i need help every mechanic i go to just keep screwing me over. i'm a 20 year old female and i need my car
Tags
20, 2004, 2005, ac, bucks, common, compression, cylinder, dodge, filter, low, neon, problems, repairs, stalls, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
