2003 Dodge Neon SXT Over heating?!?!
My 2003 Dodge Neon keeps overheating when driving just around town. I have changed the water pump about 3 months ago, changed the thermostat countless times, and changed the radiator cap. I have oil in the car and it just keeps over heating! When i down shift and get higher RPM's the needle starts to go back down. I cant seem to find any other reason as to why it's overheating, so if you have any idea, please help!
I had the same problem in my 2005 SXT. I had to bleed it to get the air out and that worked for me. When the car is cold, I positioned the car so the radiator fill tube side of the car was higher in the air than the other side of the engine. I took off the radiator cap. (Not the overflow tank) Started the car and kept adding mixed antifreeze until it stopped bubbling. Then put the cap back on while it is still running. Don't let it get to the point where antifreeze starts gushing out.
