1997 Plymouth breeze 2.0l sohc engine swap
Old 01-04-2016, 04:34 PM
Karm13's Avatar
Karm13
Karm13 is offline
Post 1997 Plymouth breeze 2.0l sohc engine swap
Hey everyone,
I have a 97 breeze the original had
A rod knock... So I found a 2002 2.0l block
Because I heard it was a direct fit, it turns out
Its production date was 9/02 so its 03 yr model
So I bit the bullet an go back an pick up both engine
Bay wiring harnesses, and fuse box,and the pcm,the interior connectors are different
My question can I make the 1997 vehicle connections,
Interface with the 2003 engine harness.
Thxs Karmie
Quick Reply: 1997 Plymouth breeze 2.0l sohc engine swap
