I've been leaning on getting lowering springs for my car. Tell me what you guys think is the best. I want something that doesn't kill my stock struts and has great performance.
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on Dodge Forums!
__________________
2004 SRT-4: Mods???
00' Neon (Downgrading close to stock)
Sponsored Links
Registered users do not see this ad. Click here to register for free!
I'm kinda disappointed in the number of replies but whatever. Thanks to those who have replied.
I'm leaning towards the mopar springs b/c they are less harmful to the struts. The cheapest ones I've found were around 230. Do any of you know of a place any cheaper than that?
i went to the dealer the other day and they said that the mopar ones were discontinued...but they were able to find some dealers that had them in stock....65.00 for front and 65.00 for rear
You've got a 2nd gen, right? DO NOT put 1st gen Mopar springs on your car. The Mopar springs for 2nd gens are just stock 1st gen ACR springs. Yes, they will lower the car, but the spring rates are nothing impressive, 10 lbs/in higher in front than stock 1st gen Highline springs... No such thing as "High Rates" or X-High Rates" for the 2nd gens.
Eibach springs (Pro or Sport) are not performance springs. Yes, I speak from experience (although on a 1st gen). 2nd gens have a little more suspension travel, so the springs might actually compress enough to become stiffer than stock (which they did not on a 1st gen), but not before body roll becomes unacceptable.
If the Voglands are progressive rates, I'd put them in the same category as the Eibachs.
You want "great" performance without damaging the stock struts? Ain't gonna happen. You either have to ditch the stock struts, or live with the 1st gen ACR springs, which are mediocre at best.
Try hunting around salvage yards for 2nd gen ACR struts if you're on a serious budget. It's going to be a tough search though, as they were only made in 2001 and 2002.
If you want new, great handling, at a reasonable price (all things considered), then go to www.phantomhp.com and look at the K-Sport coilovers, should run $1000 or so for the entire set. That includes the struts (matched to the spring rates for long life), springs (smaller "coilover" style for wheel/tire clearance), adjustable ride height, adjustable compression/rebound (single knob), adjustable camber (new camber plates up top for the fronts) - a seriously competitive setup at a bargain price. Also keep in mind that these are going to be stiffer than any of the springs you mentioned by at least double. They'll compare to the Mopar coilovers, but won't need to be replaced the first time you hit a pothole, and at a fraction of the price. So like any suspension on the Neon, you will sacrifice ride quality for handling/performance. I haven't confirmed it yet, but it looks like they are Tokico struts modified by K-Sport to fit the Neon (one of the other neon sites mentioned it).
Unlike many things on the Neon that are relatively cheap and/or easy, the suspension has a pretty steep starting point for upgrades (performance upgrades, not bling upgrades). Take it from someone who has taken big financial/time losses by trying the cheap route many times over, you don't want to skimp on suspension (this includes wheels and tires) if you are serious about handling performance.
Best of luck!
__________________
1995 Plymouth Neon
2006 Mazda5 Sport
I know nothing about cars or engines, at least according to Neon2.0T. Must be true then!
I just got m VOGTLAND Sport Springs and they rock. Just a bit firmer than stock and have no quirky unloading issues as they are a dual rate progressive spring and could not be happier. Gunter Engineering in full efect here.
__________________
2004 Neon SE -- [size=1]K&N CAI, R/T Muffler, Booger Bushings, Prothane Suspension & Race MM Inserts, Vitor's TM Inserts, Progress 22MM Rear Sway Bar w/ Energy Suspension 2 3/8" End Links, Vogtland Springs, KYB GR2 Struts, Vibrant Type V Strut Bars[/size
