poor gas milage on my sxt!
Old 07-19-2006, 11:03 PM
Jaime340's Avatar
Jaime340
Jaime340 is offline
Default poor gas milage on my sxt!
what kind of gas milage is everyone out there getting on there neon? i just got one about a week ago due to high gas prices. i have a magnum rt thats a gas guzzler in town, that we thought we werent going to drive as much couse of the gas. the manuel says the neon has 12.5 fuel tank and it gave us about 150 mi before the fuel light came on. am i not doing the math right? thats like less than 12mi per gal. however it has been about 105 to 108 in tempiture and the A/C has been on full blast non stop. please help, jaime
Old 07-20-2006, 03:46 PM
Bunta Fujiwara's Avatar
Bunta Fujiwara
Bunta Fujiwara is offline
Default RE: poor gas milage on my sxt!
yeah...im only gettin like 200 mi out of a full tank.
I thought the fuel mileage would be better in my new 2001 SE, but I think my '93 Cutlass V6 3.1L makes the same or better mileage right now!!!!!!!
Old 07-20-2006, 05:09 PM
01neon01's Avatar
01neon01
01neon01 is offline
driving mostly street i get about 270ish (22-23 mpg) but ive gotten about 300miles on one tank when driving more freeway.
Old 07-20-2006, 05:18 PM
LowSlowNeon's Avatar
LowSlowNeon
LowSlowNeon is offline
150 is pretty low. I'm at almost 100 and I'm slightly below the 3/4th tick mark. And I do not really try to conserve gas if you get what I'm saying. When I took a trip with my neone last summer I got over 300 before my gas light even came on. Generally I get about 28mpg when I just drive around town. But again, I don't shift optimally all the time either. Check your tire pressure, air filter, spark plugs, wires, to make sure its running well. I bet one or more needs changing.
Old 07-20-2006, 06:13 PM
Jaime340's Avatar
Jaime340
Jaime340 is offline
my neon still has factory and dealer warenty, it was a previous rental, so i only have 7k mi till my warenty is up. do you think the dealer or the factory can take care of the problem if there is one? or even run a test to find a problem?
Old 07-20-2006, 07:16 PM
LowSlowNeon
If there is something wrong with it they should. However if you go in there and say "my car is getting bad mileage" they'll probably tell you the mileage you're getting is normal. Most likely it is not throwing any trouble codes either so they probably would tell you its fine. It could be a bad oxygen sensor, I forgot about that earlier.
Old 07-21-2006, 12:11 AM
Jaime340's Avatar
Jaime340
Jaime340 is offline
BAD O2 CENCOR? WOULDNT THE CHECK INGION LIGHT COME?
Old 07-22-2006, 04:13 AM
Bunta Fujiwara
yeah it should. but if not, it might not be the sensor.
LowSlowNeon was right at first....u probibly just have a much needed tune up on the menu.
Old 07-22-2006, 11:53 PM
Jaime340's Avatar
Jaime340
Jaime340 is offline
my avrage now 12mi per gal i dont think all thats going to get me at 26 or 28 mi per gal.
Old 07-23-2006, 12:29 AM
03neonRT's Avatar
03neonRT
03neonRT is offline
Well I know my "Low Fuel" light comes on when I hit 220 miles, but i can always get at least 275 miles on a tank, even when the needle is way below the E it always still has at least 1.5-2.0 gallons left...and R/T's are notorious for bad gas mileage, so you should still be getting at least 275-325 miles per tank...obviously your problem is a bit more extreme, but i do know running the A/C full blast in a hot enviroment will contribute to poor gas mileage (but not 150 miles a tank poor!) because the Neon has a very strong A/C. But it sounds more serious than that, i would take it to the dealer, get a tune up, run some fuel system cleaner through there, check your spark plugs, wires, etc...
Quick Reply: poor gas milage on my sxt!
