major problems with 6.7 cummins
RE: major problems with 6.7 cummins
ORIGINAL: bksram3500
I can't remember who but I think someone traded for a 6.7
To address the recent problem with the 6.7L engine problem (DPF clogged), DC released a PCM Flash on 12 June. My truck had this done the day before I bought it off the lot (it was built in Feb 07). I have had ZERO issues with it.
The Technical Service Bulletin is 18-033-07 Rev A. After this service is performed the dealer is required by law to place a sticker on the front right of the engine compartment indicating the modifications performed. The TSB number and part number will be written on it. I also had a sticker on the PCM (firewall - passenger side). "Rev A" may or may not be written, but you can confirm the part number (below) which varies based on model (2500 vs 3500), transmission, and emissions certification (Fed vs. CA).
Quoted from Turbo Diesel Register:
"Part Numbers" for TSB 18-033-07 REV.A [hr] This number should appear on the "modification label" after a reflash is done:
[ CALIFORNIA NUMBERS ARE DIFFERENT! THESE ARE FED NUMBERS. ]
3500 auto - #55351105 AT
3500 man - #55351100 AT
2500 auto - #55350105 AT
2500 man - #55350100 AT
No distinction is given for cab/chassis models
on
You can bet he took a big loss in the pocket book when he traded them all in for them new Ferds. He will also find out they will not tow or haul as much as the diesel engine could. I also find it funny he did not give Dodge a chance to get the new flash in to the ECU to correct the problem but some people have more money then brains so what can I say except[sm=loser.gif]
ORIGINAL: teocbrent
to all who are in the market for buying a 6.7 with all of that emission junk on the exhaust, DO NOT. I am a pipeliner working in chicago area. My contractor bought 10 of these 07 dodges' with the V8 cummins, they have all stalled andbrokedown and are currently being replacedby ford gas burners. Here's why, YOU CAN NOT IDLE THESE ENGINES. yea that's right, a diesel work truck that you can't idle. That's useless.
thank god i got one of the last ones
Brent
07 2500 5.9cummins
4x4 jet black
waylon jennings lives
Brent
07 2500 5.9cummins
4x4 jet black
i bought the cab&chassis 6.7 cummins dually w/6spd auto and its done great untill now that i started working it....we are on a 16' line in midwest wy and im on the firing line puttin the lids on...or making the final weld(capping).the setups are only 40' apart and usually only take 15 to 20 mins.so its hardly practical to turn the ignition off as you may have to turn it off and on 50or 60 times a day...i bet my starter would last about 6 months..so,ive left it idling and i guess if the new motor idles for 58% of the time the catalyst becomes full and you have to drive it at hwy speeds for at least 45 mins,which isnt an option when you are an hour away from any hwy.ive heard that this can cause severe damage to the motor so im almost regrettingthat i boughtanother dodge for a work truck..winters coming soon and when it gets 40 below outside you almost have to leave it running..i heard someone saying that you can have it scanned to idle the motor up or install some sort of gadget to idle it up when its in park but so far those are just rumors.id sure appreciate some advice or information if anyone knows anything about a fix or remedy..
