Really need help
Old 08-28-2007, 05:11 PM
bway4x4's Avatar
bway4x4
bway4x4 is offline
Default RE: Really need help
Should i be able to wiggle my (i think front driveshaft) the shaft that runs from tranny to front differential? I just crawled under it and i can wiggle it side to side maybe .50 to 1 inch.
  #22
Old 08-28-2007, 06:37 PM
AKCerberus's Avatar
AKCerberus
AKCerberus is offline
Sounds sort of like you might have a loose lug nut or rocks in the hub caps. Pop them off and take a look.
  #23
Old 08-28-2007, 07:43 PM
bway4x4's Avatar
bway4x4
bway4x4 is offline
I set the E-brake and bumped it in 1st and in Reverse, you can actually hear the noise when i do that... Anyone know what thats a sign of?
  #24
Old 08-28-2007, 08:27 PM
bway4x4's Avatar
bway4x4
bway4x4 is offline
Yeah i popped all of em off and looked found nothing all fit tight. Even drove around without them and still heard it.
  #25
Old 08-28-2007, 11:20 PM
jakebrake's Avatar
jakebrake
jakebrake is offline
Is the slop in the slip joint or the ujoints?
  #26
Old 08-29-2007, 08:53 PM
Methos's Avatar
Methos
Methos is offline
Well, if it's any help I think I finally figured mine out tonight. Looks like I'm losing the rear u-joint. Definately killed it [:@]
Never heard quite this noise from a ujoint before, but there is no question the joints bad.
Strange though, I went over them all about 2 weeks ago during a maintenance period and the all looked and felt fine. This was just a couple days after starting to hear the noise. Quick inspection again tonight out of frustration of being out of options to check and, sure enough, found it bad.
