2001 Cummins
Old 10-11-2007, 11:35 PM
alansimpson04's Avatar
alansimpson04
alansimpson04 is offline
Default 2001 Cummins
im thinkin about buyin a 2001 Dodge Ram 2500 4x4 Cummins,and i was wondering if anybody could tell me if theres any know things thats wrong with this model?
also wat are some of the mods?
Old 10-12-2007, 12:14 AM
jakebrake's Avatar
jakebrake
jakebrake is offline
Default RE: 2001 Cummins
Any and all the mods you could want, although the automatic doesn't react well over about 45 horse in mods. You'll want to replace the lift pump (know problem). They fail and burn up your injection pump ($1200 part). You'll also want to check for what is known as the "53 block" Blocks with 53 cast into them are more prone to crack. Number should be cast on the lower driverside of the block. Some people are having issues with the dash cracking and some are having problems with a vibration at freeway speeds believed to be the d-line.
Old 10-12-2007, 12:43 AM
CutterW's Avatar
CutterW
CutterW is offline
I have 145,000 miles and I cracked the dash. Still original pump but I want a fass. I havent had any leaks or doesnt use any oil, at all. The only problem I have had is the auto likes to stick during winter cause its cold and for some reason we had Ujoints on driveshaft go out. But its all find now and hopely get tranny rebuilt/beefd up before long as well
Old 10-12-2007, 11:31 AM
Mayfair's Avatar
Mayfair
Mayfair is offline
All in all even with the minor problems associated with that year ( and what year DOESN'T have it's issues ) none of them would scare me away from the truck at all. Every issue ( except for the 53 block ) can EASILY be addressed.
Good luck !!
Quick Reply: 2001 Cummins
