camshaft position sensor DTC
Old 10-23-2007, 06:36 PM
woligator's Avatar
woligator
woligator is offline
Default camshaft position sensor DTC
im willing to know that if this code i trew by the ecm all i have to do is replace this sensor???
something to adjust or r&r thats all?
Old 10-23-2007, 06:49 PM
jakebrake's Avatar
jakebrake
jakebrake is offline
Default RE: camshaft position sensor DTC
What code?[sm=scared09.gif]
Old 10-23-2007, 06:55 PM
FroneDaddy's Avatar
FroneDaddy
FroneDaddy is offline
Is it P0340?
Old 10-23-2007, 06:56 PM
woligator's Avatar
woligator
well i dont remember the number lol but its the camshaft position sensor code,ill check in a min guys
Old 10-23-2007, 06:58 PM
FroneDaddy's Avatar
FroneDaddy
Theres about 4 camshaft position sensor codes
Old 10-23-2007, 07:31 PM
woligator's Avatar
woligator
PO341 camshaft position sensor A circuit range/performance bank 1 or single sensor
PO216 injector/injection timing control circuit
P1690 info not available
Old 10-23-2007, 08:37 PM
Drew's Avatar
Drew
Drew is offline
your lift pump just took a dump and will be dragging your VP44 to it's grave. . .you better not use your truck again untill you get your lift pump replaced
Old 10-23-2007, 09:05 PM
woligator's Avatar
woligator
Are u serious drew?
well its goes around on my rpm gauge into my dash and got my hard time on acceleration but i can erase code and it work nicely for a bit then rpm gauge quit and i reset code again then its ok..
been like this for at least 3 weeks,ive been to the dealer 2 times but the diesel tech was not there and they didnt called me back
So if i follow ur point i better hurry order a fass right?
Ill need one anyway if im on my way to bigger injector right?
Old 10-23-2007, 09:22 PM
Drew's Avatar
Drew
Drew is offline
youve got mail
Old 10-23-2007, 09:27 PM
woligator's Avatar
woligator
NOOOOOOOOOOOOOOOOO not my vp44.....
ill have to buy a hotroded vp44 and a fass all at the same time damn!!!!
maybe injector will wait a bit
Quick Reply: camshaft position sensor DTC
