2010 3500 tires rubbing!!
Old 10-06-2014, 11:13 PM
MacNeil4's Avatar
MacNeil4
MacNeil4 is offline
Default 2010 3500 tires rubbing!!
Hey guys, i got a 6 inch bds lift in the truck with 35 x 12 in federal tires. When i turn fairly sharp the tires are rubbing on the mud flap a tiny bit. Also it is rubbing away a bit of my control arms as well. Is there any thing easy i can do to fix this issue because i would like to run 37's if i can. Thanks!
Old 10-07-2014, 11:03 AM
p38251's Avatar
p38251
p38251 is offline
What are you running for rims? I have a 12 2500 305/70/17 nittos. Stock rims, they rub at full lock as well. Rims with different off set and back spacing would fix the issue.
Quick Reply: 2010 3500 tires rubbing!!
