Power Loss/Smoke Problem
#31
RE: Power Loss/Smoke Problem
Mike, I got your e-mail and I'll answer it here. I would do what the others have advised here. . .get the pressure on the lift pump tested. you should have better than 12psi at idle. around 8psi while running down the road and no less than 2-4psi hammered down.
I would be more concerned with the hammer down pressure. if at any time it drops to zero I would just goahead and stop driving as quickly as possable.
your best bet as far as ease of instalation would be a walbro pump setup from Glacier Diesel performance. the Fass pump is also very good in that the filters actualy filter to a lower micron size than the stock filter.
#32
Thanks Drew. All of my power loss problems were fixed with properly changing the fuel filter, then fixing my mistake of not priming it before trying to start it. I said in a previous post that its like a whole new truck.
Im still going to check the fuel pressure just to make sure it wasnt a combination of bad fuel filter plus weak lift pump. What fuel pressure gauge would you recommend for testing at anything other than idle, i.e. me standing on top of the truck reading a gauge...i have very limited budget here and the gauge would probably have to be able to be understood by cavemen and some of your more domesticated house pets.
#33
