6.7L update questions
I'm looking to order some performance adders to my 07.5 2500 diesel
I'm honestly not after a hot rod I just want this fuking truck actually run correctly.
I live in northern Michigan and I use the truck pretty hard towing lots and plowing lots. Due to the plowing I'm plugging up the DPF frequently.
I'm looking at ordering the
h&s mini maxx
Farmboy's 5" turbo back with muffler
AFE stage 2 intake
I'm new to the CTD world how does my idea look? I'm not doing EFI live I want to reach up to the dash and go from stock to tow, to stage 5 go like hell.
Thanks for your help.
- Brian
h&s mini maxx
AFE stage 2 intake
- Brian
Sorry, I know this thread is super old. Mr. Beefy, when you cut the downpipe did you save the DOC (diesel oxidative catalyst) that was in the pipe? I would like to buy a DOC from one of you guys that comes in that OEM downpipe. I'm not a cummins owner but do run diesel. My car has stink and trying to clean it up.
On a different tangent, if no one here wants to sell me this part, do you know where i could seek used 6.7L OEM downpipe?
Here is my story. I run a BMW 335D dpf delete (which means i lost the DOC within the DPF cannister). I'm looking at other mods down the road that will open up rest of exhaust downstream of where the DPF used to be. Loss of back pressure actually spells trouble for my 2 turbo system. It will overboost if too little back pressure unless other mods are performed (like opening up big turbo's wastegate to larger diameter). This is a little 3L small turbo/big turbo straight 6. Pretty good power considering small displacement. But the smell is pretty damn bad. Going back with a DOC will only add back a small amount of back pressure. Thanks for your consideration.
