Towing issue
Towing issue
Hi : 2002 ram 2500 diesel everything runs and works fine until I tow my trailer (which is fairly heavy) I get a shuttering when I try to maintain speed when climbing a hill,not sure if it's from engine or transmission , when it happens I have to back off and baby it up the hill,this only happens under these circumstances .Note trk has some up grades KnN air , larger exhaust , and cortex chip programs .I suspect maybe torque converter but want to check other avenues first .Thks for any guidance
OK, I got ride of a 2003 Ford F250 PSD. I had the Banks 6 gun tuner. When towing I could not use the tuner except in the stock setting. If possible, remove the Cortex chip and see if it still does it.
I also had a bigger exhaust, K&N, turbo upgrade, chip, and more. My turbo would shutter while towing and going up hill. Hope that helps.
