DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Vans > Dodge Ram Van
Thread Tools Search this Thread
Old 05-22-2008, 09:18 PM
rpecori63 rpecori63 is offline
Default AC/Fan Control problem, help please
1998 Ram Van B1500, Elk Conversion.
I'm having some issues with getting Air/AC to blow out front vents. Have no problems with feet/defrost vents. But most of the time whenset to Face, air blows out Defrost and/or Feet. At speed (60mph) Air willnot blow out face vents...when speed is reduced air will switch from defrost/floor vents to face, but not all the time. Or if I adjust temp. control from full cold to a warmer temp the air will switch from defrost/floor vents to face vents. Any ideas of the cause, possible solutions, or tests to narrow the problem would be appreciated.
Very frustrated, looking under dashthere are many vacuum hosescoming from blower control, blower speed control, and temp. control. This has been serviced before for AC problems and speed control, so it might be possible that some vacuum hoses were hooked back up wrong.
Any diagrams of vacuum hose routing? They are color coded.
Help! I need my AC to blow in my Face.
Thanks,
Hot in Florida
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
__________________
Robert A. Pecori
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 05-22-2008, 10:25 PM
alloro alloro is offline
Default RE: AC/Fan Control problem, help please
Here's the vacuum connector pin-out and switch logic. Perhaps these might help you in narrowing down the problem.
[IMG]local://upfiles/49302/813092F3B70E4619BD8CFD09982401CA.jpg[/IMG]
Old 05-23-2008, 11:16 AM
Thanks Alloro!
I ended up taking the AC Fan control out and disassembling it with the vacuum hoses still hooked up. The control body is a 3 piece assembly. I did unhook the 2 electrical connectors also.
When I re-assembled it everything worked! Ican onlyattributethe problem being an electricalcontactissue.I believe that was the same problem I had with the fan speed control also.
So for anybody elsewho might haveproblems with the fan control or speed control, you might want to try disassembling the control and re-assemble,your problemcould be just a contact problem.
__________________
Robert A. Pecori
Old 05-24-2008, 12:05 PM
Just wanted to add, the fan was still switching to defrost/floor when I got on the highway.
I found one vacuum hose (White) broken off in the engine compartment up front. It broke again when trying to fix it, very aged and brittle. I also found another vacuum line (Black) that was cracked from age in many spots. There are 3 smaller vacuum lines coming thru the firewall that probably are the cause of many fan/blower issues. I will be looking for new vacuum hose to replace the old and brittle original ones.
thanks again Allero
Cool in Florida
__________________
Robert A. Pecori
Old 05-24-2008, 12:36 PM
Mobile Auto Repair's Avatar
Mobile Auto Repair Mobile Auto Repair is offline
Vehicle: Ram B2500 Van
I had the same problem with my Chevy Impala with the plastic vacuum line. What I did was find a rubber vacuum line that I could put the plastic one into (I found one that fit very snug) and ran new line back to where the plastic line was not brittle. I hope this helps.
__________________
Switchable IAT Mod for Magnum Engines
1997 Dodge B2500 Custom Cargo Van, 5.2L, 344K total miles.
Old 07-25-2009, 01:14 PM
gerohan gerohan is offline
a/c vent in front dash don't work they were but i changed the heater valve and it stopped working how do i fix the problem? anyone?
Old 07-25-2009, 01:16 PM
can anyone tell how do the vacuum hoses to a dodge ram van b250 are put together?
Tags
ac, chevy, dakota, detail, dodge, fan, floor, hose, intrepid, pinout, ramvan, routing, stopped, vacuum, van, vents, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
