DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Vans > Dodge Ram Van
Thread Tools Search this Thread
Old 04-19-2009, 11:35 PM
rntvin1 rntvin1 is offline
Unhappy 1995 dodge ram van discovery conversion
I have a 1995 dodge ram 2500 van with a Discovery conversion........i have 3 problems that i cant figure out....first I have no headlights....i pull the switch on and i have running lights and if i attempt to pull on the high beams they go on as long as i hold the switch back.......2nd I have no blower motor in the front for the fan on the heater /ac.....and third i have no power windows.....I have checked all fuses....just not sure what to do next............this is my familys only transportation and i really need some help.......please someone i am sure has had the same porblem and can tell me what to do so I dont have to spend 100's of dollars
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 04-20-2009, 12:01 PM
alloro alloro is offline
1. Replace the headlight switch.
2. Replace the blower motor speed resistor.
3. Pull out the power window switch and see if there is power going to it. If there is, replace the switch.
Old 04-20-2009, 10:20 PM
Thank You
I have replaced the head light switch and it now works...............i will find the part for the blower.......and if I dont have power to the window switch...(the reason I ask is none of the power windows on the left or right doors work
Old 04-21-2009, 02:25 PM
You can get the resistor from the dealer for like $10-$15. It's mounted on top of the big black box under the hood on the passenger side, with a 4-wire flat plug going to it.
If you have the dual window switch on the driver's side and it's no good, the passenger window will not work either.
Old 04-21-2009, 10:45 PM
Smile Power windows
Quote:
Originally Posted by alloro View Post
you can get the resistor from the dealer for like $10-$15. It's mounted on top of the big black box under the hood on the passenger side, with a 4-wire flat plug going to it.
i have removed the dual switch on the drivers side......should i have power in any of the small plug holes on the plate that i removed the switch from......if so none of them have any power.....but i do have on my locks
Old 04-22-2009, 02:06 PM
You should have 12 volts at the switch (with the key on). If you do not, then you might want to check the fuse again. Instead of a fuse, there might be a circuit breaker in the fuse box for the windows. The breaker is usually silver, about 1" long, 1/2" high, and 1/4" wide.
Tags
1995, 2500, accessories, conversion, converson, converstion, discovery, dodge, history, kit, light, oil, ram, switch, van
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
