DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Vans > Dodge Ram Van
Thread Tools Search this Thread
  #31
Old 07-25-2009, 06:36 PM
gregstukey gregstukey is offline
Quick question. Is there another way I can drain the block? My block drains are super corroded and I dont feel like this could have a good ending. So, before pulling the intake manny how can I be sure the block is empty so that coolant doesnt flow into the cylinders? Are the drains the only way?
Thanks,
Greg
ps--drained radiator and pulled upper and lower radiator hoses from circ pump/intake manny.
pss--how does the fuel fitting come off the driver side fuel rail? special tool? or just pull?
thanks.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
  #32
Old 07-25-2009, 06:54 PM
lilredex's Avatar
lilredex lilredex is offline
Quote:
Thanks,
Greg
The other way to drain the block is to knock out frost plugs.........but I don't think you really want to go that route. They come originally with a 1/4" NPT steel plug. Get a 6 point (9/16") socket on there and remove them. They can be tough, but they will come out. Good time to flush out the junk in there also. Put in brass petcocks when you are finished.
  #33
Old 07-26-2009, 11:01 AM
As for the fuel fitting to the rail---is there some other way of removing the quick fitting without a "special tool?"
-G
  #34
Old 08-01-2009, 11:44 AM
Ok---we're downtown. Got the head off successfully. The cylinder in questing is the second one from the front on the right bank which I believe is #4. Anyway, its hard to see any leak there but it seams as though the seat is damaged/warped on the exhaust valve. The valves are very wet looking and quite a bit of residue (from the fuel not being ignited i assume) is caked all around. All valves are pretty black.
Is there anything else I should look for? Gasket was pretty clean and in one piece. Ill try to post some photos.
-G
  #35
Old 08-05-2009, 02:15 PM
carpetvan carpetvan is offline
Vehicle: 1987 dodge ram van se 250
Smile
sounds like a valve guide problem(worn) or bad rotators or broken valve spring. which in turn burnt the valve/seat. a automotive machine shop will tell you the whole story. if there are rotators on the exhaust valves have them replaced or replaced with solid non rotators. rotators look like a thick valve retainer. like the intake has(thin)
  #36
Old 08-05-2009, 09:58 PM
Its totally a bent exhaust valve stem. Looks like the leaning tower of Piza when you put it on a true surface.
Thanks to everyone for the help in the diagnostic. Now for the reassembly....
  #37
Old 08-05-2009, 10:16 PM
Mobile Auto Repair's Avatar
Mobile Auto Repair Mobile Auto Repair is offline
Vehicle: Ram B2500 Van
What caused it to bend? Look to see if it hit the piston. If so then I would look at replacing the valve spring and lifter for valve.
__________________
Switchable IAT Mod for Magnum Engines
1997 Dodge B2500 Custom Cargo Van, 5.2L, 344K total miles.
  #38
Old 08-06-2009, 07:56 AM
Going with a reman'ed head with new springs, guides, etc. The piston looks like it wasnt hit. No scratch on it and there's nothing broken off the valve...
its definately strange....it must of hit right? what else could bend the valve?
  #39
Old 08-23-2009, 09:42 AM
150 psi across the right bank. Stoked. Engine running well...waiting on a new cat. Thanks for all the help throughout the process.
-Greg
Tags
1995, 1997, caravan, compression, cylinders, dodge, fuel, intextauto, intrepid, rail, ram, remove, repair, rt, stealth, stratus
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
