DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Vans > Dodge Ram Van
Thread Tools Search this Thread
Old 07-01-2009, 05:22 PM
82B250CDN 82B250CDN is offline
Vehicle: 82 B250 Camper/ 2006 Cobalt SS
Send a message via MSN to 82B250CDN
Arrow 1982 B250 Questions
Here is a couple of questions for the people who have some knowledge.
First, I have tried everything with this van to get it to run leaner, If it runs on high idle for more than 30 second it will run rich and belch black smoke out the tail pipe. If I start it with out using the high idle on the carb it runs leaner but still puffs small amounts of black smoke. Short of putting a new carb on it I'm not sure what else to try. Any Suggestions?
Second, This van has been converted I'm assuming from a passenger van to a camper it has a raised roof but there are things missing for the camper conversion like a converter (for Power) and all of the proper wiring. the older guy who owned it before me really kinda rigged everything to work. But I have some electrical issues ( LOL ) sometimes the interior lights work sometimes they don't I have cleaned the switches on all the doors but still only the front door switches work when the interior lights are working. When I tried to get the glove box light to work I almost had a dash fire. So I just left that disconnected.
A little more info on the van it has a 5.2 and not sure what transmission but after wires, plugs, rotor, and cap and timing check all spark knock is gone and it is running much stronger. I have done all the regular maintenance things the more I do the better it seems to get, but the burnung rich problem stumps me I love this van and don't want to give up on it. P.S. I only paid 260.00 canadian for it so I have been doing all of the work on it myself to keep costs down if there is any help out there for the problem with the carb I greatly appreciate it.
Thanks in advance
Jacob
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 07-01-2009, 06:05 PM
kev2 kev2 is offline
BASICS:
suggest you get a vacuum gauge, best tool for working carb (old school) engines..
1982-been a while so memory is rusty especially at my age...have you if applicable adjusted mixture?
running rich: carb may have a problem with float level, needle and seat, etc...will get you some how-to info.
does the choke open fully and is pulloff operating?
Sometimes the thermostat may be removed and engine never gets to operating temp.
Old 07-01-2009, 06:48 PM
lilredex's Avatar
lilredex lilredex is offline
I'll assume you have a Carter BBD carburetor which is common on those.
Check to see that the choke pull off is operating and the choke is set properly. Should work like this-- cold. Press down accelerator choke snaps shut, engine starts and pull off pulls choke open 1/4". If it operates in this fashion but is still "chugging" open choke a bit more with a screwdriver. The stroke of the pull off is adjusted by pinching the linkage to make it shorter if need be. That is one of the most common rough idle and black smoke problems. As it warms up the choke should open fully.
http://www.carburetor.ca/carbs/kits/CK021.htm
Old 07-04-2009, 05:42 PM
Default Thanks Guys
Thanks guys everything you have stated I have done I guess I am just going to have to rebuild it. But I must say it does get better the more I drive it. I'm off on a 1300 km trip today so I'll let you guys know when I get back how everything went. Thanks for the replies. Jacob
Old 07-05-2009, 12:37 PM
lilredex's Avatar
Again, assuming it is a Carter BBD, I have a chart that shows all the dimensions for those metering rods and jets they used. Also figured out the best combination, if you want that also. Just ask.
Tags
base, bbd, carburetor, carter, dimensions
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
