DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Vans > Dodge Ram Van
Thread Tools Search this Thread
Old 08-02-2009, 03:50 AM
NikLaw1 NikLaw1 is offline
1999 Toyota Tacoma
My Garage
Vehicle: 1991 Dodge Ram 250 Conversion Van
Default Bought 1991 Dodge Ram Conversion Van 250 - Electrical Trouble Shooting
I made a post earlier. I was hoping someone might be able to point me in the right direction.
1) Wipers don't work, i suspect its the wiper switch.
2) Horn doesn't work
3) Power Window's don't work
4) Power Locks don't work
5) Air / AC doesn't work. Doesn't blow anything,
(a) rear blower does work. Only blows warm air.
Cigarette lighter does work
Headlights / Taillights work
Dash Lights work
Cabin Lights work
Glovebox Light Works...
I've checked and replaced all fuses. My band bought this van as a tour van - investment. We got it because the motor seems to be running great, and the transmission feels smooth.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 08-02-2009, 11:22 AM
lilredex's Avatar
lilredex lilredex is offline
Quote:
Have you checked to see that there is power at those fuses in the fusebox? No power -- get a circuit dwg and work backwards to see how they are powered. Sometimes it is just a crappy connection comming through the firewall.........that big plug behind the battery.
Old 08-02-2009, 01:50 PM
alloro alloro is offline
To me, it sounds like a fried fusible link feeding the ignition switch.
Old 08-02-2009, 02:17 PM
1999 Toyota Tacoma
My Garage
Great, i appreciate both responses.
Does anyone have a picture of what the "fusible link" that i can look for as I'm checking the wires?
-Thanks
Nik
Old 08-02-2009, 02:22 PM
1999 Toyota Tacoma
My Garage
Quote:
Awesome, when i get back to the van today I'll look for the connection.
Old 08-02-2009, 08:16 PM
Old 08-02-2009, 08:23 PM
1999 Toyota Tacoma
My Garage
Quote:
Originally Posted by alloro View Post
I checked the fusible link, and all the wiring looks great. So if i start tracing from the battery, next in line is the fuse box right? is the only way to access the leads into the fuse box is by removing the dash?
-N
Old 08-03-2009, 11:55 AM
lilredex's Avatar
[[Have you checked to see that there is power at those fuses in the fusebox? No power -- get a circuit dwg and work backwards to see how they are powered. Sometimes it is just a crappy connection comming through the firewall.........that big plug behind the battery]]
Guess I wasn't clear here. Get a test light and confirm that there is or isn't power on BOTH sides of the fuses in question (not on the fuse but the clip holder). Then you know what direction your search should be. No power you need to go backwards towards the battery to find a faulty connection ( Plug mentioned above, fusible link, etc.) A circuit dwg is most helpful so you know where you are going and what you are looking for. You cannot do a "visual" on a fusible link. If you do have power, you need to direct your attention in the other direction and look for faulty connections, bad switch, etc. A test light (and a dwg) will be your friends in both situations.
No need to tear anything apart..................yet. You have to find the problem.
Old 08-03-2009, 03:04 PM
1999 Toyota Tacoma
My Garage
ok so we got a wiring diagram and we're gonna start tracing it today. But how to I access the back of the fuse box? I tried pulling the screws and wiggling it out into the open cavity of the glove box and it seemed to just not wanna go. Do I need to pull the whole dash to access the backside of the fuse box?
-Nik
Old 08-03-2009, 04:38 PM
Shadow67 Shadow67 is offline
Vehicle: Anything
Just going by the list of works/don't work, I would check the ignition switch. I couldn't say with absolute certainty, but it's quite possible all the don't works are things that are disabled whe the ignition switch is turning over the starter. Could be that the bypass to those circuits has managed to become permanent.
Tags
1991, 2009, 250, conversion, custom, dodge, free, manual, online, operators, ram, troubleshooting, turning, van, vans
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
