DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Vans > Dodge Ram Van
Thread Tools Search this Thread
Old 08-17-2009, 08:25 PM
Linb1 Linb1 is offline
Vehicle: 2002 Ram Van 1500
Default Help! Van Died!
2002 Ram Van 1500, V8, just quit a mile from home after running fine for most of my 25 mile commute. No fanfare or noise, just died. Also noticed speedo went to 0 although I was going at least 30 when it happened. Battery good, has gas. checked all fuses (including the ones in the black plastic box under the hood), all look OK. Odometer blinks the mileage several times, then displays "no buS".
Can't afford another repair, just had water pump changed. Any ideas on something easy I can try?
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 08-17-2009, 10:17 PM
Default Update
I went back with a friend about an hour later and it started! Ran fine, everything worked. At least I don't need a tow. But what could have caused it, and should I fear driving it until I can afford to put it in the shop?
Old 10-19-2009, 10:24 PM
oasysco oasysco is offline
Vehicle: 1994 Ram Van B250 conversion
Quote:
Check your battery cables. One may be loose or have some buildup on the post.
__________________
GregD
SE Virginia
1994 Dodge B250 MarkIII conversion van
Old 10-26-2009, 10:48 PM
Virmagicus Virmagicus is offline
Check the coil & or replace.
Old 10-26-2009, 11:01 PM
The Van Man The Van Man is offline
Vehicle: 1999 Dodge high-top conversion Ram Van
Send a message via AIM to The Van Man
I noticed you posted this back in August. I was curious since I have a Ram Van also, did you ever figure out what the problem was?
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
