DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Vans > Dodge Ram Van
Thread Tools Search this Thread
Old 08-29-2009, 03:41 PM
walk1169 walk1169 is offline
Default 1995 dodge b2500 wont stay running when hot
Hey,I have a 1995 dodge b2500,5.2 litre. This thing runs great until it gets warmed up.i have cleaned the IAC,replaced the tps sensor,change the heat sensor,Dont know where else to look.could the tb be bad? it has codes 12,22,24,55.is there a way to clear these code without spend a handful of cash??? does anyone have an idea or thought of what maybe causing this problem? is there a chance that the tcc sensor is bad as well? Thanks
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 08-29-2009, 05:42 PM
alloro alloro is offline
Replace the ignition coil. Then disconnect the battery for 10 minutes to clear the codes. You can also go to Autozone and they will clear the codes for you with their code scanner.
Old 08-30-2009, 08:14 AM
I already went there and they cannot clear only 96 and up.that is a good idea with ignition coil. i will give that a try to see what happens.Thanks........
Old 08-30-2009, 12:22 PM
Mobile Auto Repair's Avatar
Mobile Auto Repair Mobile Auto Repair is offline
Vehicle: Ram B2500 Van
Quote:
Autozone and all other auto part stores here in Texas are not allowed to clear the codes, only read them. Only the owner or their mechanic can reset the PCM.
I understand that this is either a Federal law or soon will be. The reason is so the Emission Testing Centers will know if the vehicle can pass the emissions test or not. By clearing the OBD-II codes it resets the computers self monitoring system and it has to retest all the emission sensors to be sure that they are performing correctly. My code scanner shows me whether the PCM is ready or not and which sensors it is still needing to pass the tests. Most times just after reseting the PCM the owner will have to drive two to five days of normal driving to get all the sensors emission test ready.
__________________
Switchable IAT Mod for Magnum Engines
1997 Dodge B2500 Custom Cargo Van, 5.2L, 344K total miles.
Old 08-31-2009, 08:47 AM
I replaced the coil and it still stalls. only a few times after it gets warm.It surges sometimes and runs great other times. looks like i am going to place one piece at a time until fixed.$3000 times hours of labor and parts. should have bought a new van.Throttle body and ecm is next on the list???? need some ideas......Help required...LOL.....Thanks
Old 08-31-2009, 01:19 PM
Quote:
Hmm, is this a change in it's behavior or is it the same?
Old 09-01-2009, 07:55 AM
Thanks for your time Alloro,this thing is driven me crazy.Yes and no,it runs great while in drive and idle for sometime. back and forth to work. 32 miles(one way).when i get home i put it park let it sit for a few minutes then it will not idle nor will it go in gear with out stalling.if i rev up engine to 3000 and run for a few seconds it clears up and runs great.(black smoke come out exhuast.not a lot) then same thing happens after a 2 miles down the road. just won't idle sometimes.rpms will not stay the same at idle,however if i touch the throttle so little it runs great.it just loads up for some reason.thinking the ecm or the TB is bad.also sound like the ecm does not reset it self. could this happen? also this thing run greats when cold.(new Jersey) it will idle all day until you drive it,until you put it in gear.you can hear that it is drops rpms then wants to go. Yes I thought about the TCC sensor???
Old 09-01-2009, 01:31 PM
when i get home i put it park let it sit for a few minutes then it will not idle nor will it go in gear with out stalling. if i rev up engine to 3000 and run for a few seconds it clears up and runs great. (black smoke come out exhaust. not a lot)
This here sounds like a problem with an injector sticking open.
Are they the original injectors?
Have they ever been removed and flushed?
Old 09-03-2009, 10:19 PM
I would thank you all for your help.However it was all wrong but very helpful.The problem was very easy and you will never know what it was???? IT WAS THE SENDING UNIT FOR THE TEMP SENSOR TO THE ECM. So easy however so far off base,$20 fix after spending 300 in other sensors.in which i took back all of them.lol... the temp sensor was sending wrong engine temp to the ecm,in whinch was flooding out the engine.learn something new everyday.Thank you all once again......
Old 09-03-2009, 10:52 PM
Very interesting. On my van when I bought it the PCM temp sensor harness was disconnected. With it not hooked up the engine kept a high idle, about 1,000 RPM's, and did run richer for the PCM kept thinking that the engine coolant was cold. Did not have any issues with it trying to stall.
In your first post you said you changed a "heat sensor", what sensor did you replace that did not help the problem?
__________________
Tags
1995, 1997, awhile, b2500, caravan, cargo, dies, dodge, hot, ram, running, stalls, stay, van, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
