On the back of the engine are two freeze plugs. When either of these start to leak the antifreeze will run down the back of the engine and drip out the bottom just where you're seeing it. In order to access these two freeze plugs, the tranny has to come out. You MIGHT be able to confirm this and see the leak if you remove the crank sensor and shine a bright light into the crank sensor opening. The crank sensor is the one on the top of the passenger side of the tranny held down by two bolts and has a 3-wire connector, right where the engine and tranny mate.
dont use stop leak that causes more probs down the road. before condeming anything get a trace dye at any autoparts store and a black light this will make pinpointing ezer. get a cooling system pressure tester i think you can rent one from autozone for free. freeze plugs rarely blow out but they do rust and develop pin holes to eventual complete failure but its not like blowing out just progressively more leaking.
Hi shelbydaytona,
Thanks for your input. I'm going to start with Alloro's suggestion with crank sensor and if I can't spot it there, using dye and pressure test as you suggest.
PIA that manufacturer would hide these at tranny/engine juncture.
True but we can at least count our blessing that the tranny comes out of these vans very easily.
If you're in a pinch, slowly pour in a 1/4-1/2 of a tube of the aluminum power sealer. I've found that using this little amount won't cause any clogs or other problems, unless there is a problem ready to happen anyway.
i'm sure everyone will disagree with me, but with the freeze plug leaking on the back of the engine and having to remove the transmission to fix it ---- i'd try some stop leak.
__________________
01 1500 Reg Cab 4wd 5.2 auto 3.55 285/75/16 nasta step bar tow hook sc3815 180 3923 trans cooler/filter posi-lok powertrax noslip timbren brite-box pioneer head rockford amp/speaker cobra cb firestick hughes plenum water pump timing chain oil pump rear seal front bearings brakes shocks cracked dash towing composting boat.
Yes, the aluminum powder is a leak sealer, you will find it in most all auto part stores and it is about 3 inch high tube in a cardboard package. The same company also makes a copper powder as well, and they are usually side by side on the shelf with other leak sealers.
I do not remember what the brand name is of the product.
