DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Vans > Dodge Ram Van
Thread Tools Search this Thread
Old 10-24-2009, 06:24 AM
gregstukey gregstukey is offline
Default Cat glows red
I got a new cat and Y pipe from Magnaflow and took the van (3500 with a 5.9) around for a spin. When I got back I made a visual inspection to the cat and saw it was glowing red in the center. I understand that this can be cause by unburned fuel fogging through the engine----
I guess Im asking how concerned about this should I be? I dont feel like this should be normal but this is my first new cat install. I remember in the past the van floor getting quite hot---almost to hot to touch the rubber flooring and that was with the oem cat.
Should I be concerned and what should I look at as a cause??
Thanks,
Greg
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 10-24-2009, 01:57 PM
alloro alloro is offline
Quote:
Yes it is a cause for concern. Catalytic converters do get hot, but they're not supposed to turn red hot. This is a sign of unburnt fuel getting into the CC.
Old 10-24-2009, 03:03 PM
So what could cause a rich running condition where the ecm controls the mix?
I've recently replace a head, plenum gasket, plugs, wires, cap, and rotor. Where should I look and is my brand new cat cooked? Runs well, no miss under acceleration and maintains a consistent idle. No signs of overheat. Only the cat glows and nothing in the pipe before and after. It takes about 5-10 minutes of running at idle for it to glow.
Thanks,
-Greg
Old 10-24-2009, 08:14 PM
You didn't specify a year for the van so I'll assume it's fuel injected. In this case, a leaking fuel injector or a bad O2 sensor would be the first things I'd test.
Old 10-25-2009, 08:59 PM
Sorry, its a 2000 and it is injected. What about the fuel pressure regulator/filter? I know its an extended life item but im up to 195K and, as we are just hypothesizing, im wondering if that could contribute.
But, i will do a pressure test to the fuel rail and what is the best way to test my O2 sensors assuming I have no access to a diagnostic scan tool---other than an engine code reader.
By the way, I have no engine light indicating anything is a miss.
Thanks,
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
